Old 04-22-2007, 09:19 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Removing inner fenders
How hard is it to remove the front inner fender (wheel well). I looked at it today and I think I can just unbolt it, and drop it out once the wheel is off. Is this correct?
I want to clean it up and repaint it. Not sure what they cost to replace, but I may go that route if not too expensive.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-22-2007, 09:24 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: Removing inner fenders
Pretty easy...did mine to replace the heater core. remove several bolts around the wheel opening and a few at the top, kinda under the hood hinge. forgot about the couple under the grill/rad support.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 04-22-2007, 10:34 PM   #3
Sport/Truck
Sierra Grande Club
Cool, so I was correct in my assumption. Are they expensive to replace??
s/t
Old 04-22-2007, 10:57 PM   #4
sick69
sick69's Avatar
I believe they are about $200 a pair retail or you could search the yards and classifieds and maybe find them for less.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 04-22-2007, 11:01 PM   #5
1969k10stepside
Mine were a P.I.T.A. but that was because the bolts were rusty.The clips that act as a nut started spinning when I would loosen the bolts and I would have to put visegrips on them to hold them.Several bolts hold them on,there is atleast one that bolts to the bottom portion of the cab too,IIRC
You,being from the south,shouldnt have much problems,just squirt with WD 40 first and you should be ok
1969k10stepside is offline   Reply With Quote
Old 04-23-2007, 10:27 AM   #6
timcos
Chief Honcho In Charge
timcos's Avatar
http://67-72chevytrucks.com/vboard/s...9&postcount=23
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
