Old 04-22-2007, 11:08 PM   #1
hiridn69gmc
hiridn69gmc's Avatar
rear diff question
The other day I was sitting at a friends house and we were wondering if my truck had a limited slip.
Well the easiest way, lay some rubber.
He was on the drivers side of the truck when I stomped on it and sure enough the tire spun, cool I thought.
So I took off and looked behind me, only one trail
Now my question is, were there ever and open diffs where the left side took the power? I have never seen and it was pretty funny. But if it isn't supposed to do that, it needs fixing. More to add to the list.
1971 Chevy C-10-sold
1969 GMC 4x4-sold
1997 Chevy Z71
2003 Grand Prix
hiridn69gmc is offline   Reply With Quote
Old 04-23-2007, 12:06 AM   #2
rage'nrat638
rage'nrat638's Avatar
Re: rear diff question
hummm something sounds funky..
better do a rear diff fluid change just to look inside for chunks.. chances are it needs it any way
rage'nrat638 is offline   Reply With Quote
Old 04-23-2007, 02:48 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it isn't made to send power to the right... it just happens that way.
The power will go to the tire with least resistance. When you romp on it, the torque unloads the right rear.
So, SOMETHING is causing resistance on the right rear, and that sends the power to the wheel more likely to spin... the left.
I'd start with the brakes... jack it up and try to turn the right rear by hand (in neutral with both tires in the air)
Old 04-23-2007, 12:46 PM   #4
hiridn69gmc
Sounds like a plan. I will take a look at the brakes and change the fluid. And go from there. Thank you.
1969 GMC 4x4-sold
1997 Chevy Z71
2003 Grand Prix
Old 04-23-2007, 05:42 PM   #5
2nd_wnd
2nd_wnd's Avatar
My DD did the same thing, it left one heck of a black mark but only with left tire.
My spid said posi, and on dirt they will both spin like mad.
I think my posi is just wore out, and your's might be the same
72 LWB
2nd_wnd is offline   Reply With Quote
Old 05-01-2007, 09:20 AM   #6
hiridn69gmc
I will have to pull the cover sometime soon. Just got a new rear spring kit. Have to do a motor swap, then some new brakes all the way around...and I'm sure both wheels spinning will keep dropping on the list of acomplishments!!
Oh well....
1969 GMC 4x4-sold
1997 Chevy Z71
2003 Grand Prix
Old 05-01-2007, 09:49 AM   #7
Orange
Licensed to Thrill!
Orange's Avatar
Man - you sound like I guess every other guy that has a list to do.
I have had a brand new brake booster/master cylinder setup to try to install for a month now.
It is sitting beside my new rear sway bar (over a year old) which is beside my center seat belt.
Don't you love it though?
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 05-01-2007, 02:54 PM   #8
hiridn69gmc
Yeah, I love it the money never stops finding its way into the truck. The problem is I need a good way to replace it in the pockets!!
Yeah, the rear isn't making any noises or howling or anything and no leaks. So I will probably just change the fluid and take a look up in there. And go from there.
1969 GMC 4x4-sold
1997 Chevy Z71
2003 Grand Prix
Old 05-01-2007, 04:57 PM   #9
84_4x4
84_4x4's Avatar
my rear end is confusing when i first slam gas both tires spin for about a foot then just right tire and it will spin until i let up on gas or get to speed but why doesent the left one stay spinning is they both do at initial take off
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 05-01-2007, 05:22 PM   #10
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
This is correct info
Now if your posi is worn out, then you don't have a posi anymore
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
