Weird Story About my Neutral Safety Switch
When i first put my new column and neutral safety switch, my engine would turn over and start fine in park and neutral. The next time i adjust my column, i can only start it in neutral and not park. So now for a third time a adjust my column and guess what now it will only turn over in the drive position. so anyways my question to you is why is this happening??
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Re: Weird Story About my Neutral Safety Switch
You had it right the first time. Starting in park and neutral is what you want. Adjust it back to that point.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
unfortunately i dont know wat that point is so there for im screwed!!
its all about the +6 inches
Have an assistant stand in back of the truck.
Chock the wheels, or use the parking brake if it is good. Place shifter in reverse Slide the switch back and forth untill the back up lights are on. Test it in park and neutral... it should be good. Have a drink and complain about your back hurting from doin the under dash boogie. |
