The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
67-68 Chev radiator Olymia WA
Replaced this with a larger one with electric fan.
$50.00 with shroud- never overheated or leaked when pulled. Has Trans fitting but I ran it with an external cooler. Not sure if the trans lines work. The tag says IA over XG, the big letters are AC Local Pickup Only Please respond here in thread- Thanks for looking
Dave 69 GMC SWB 2WD 454 Turbo 400 |
Re: 67-68 Chev radiator Olymia WA
ttt
ttt
ttt
Perfectly usable as is...
Price now $40
ttt
last try- $35
What fan did you put in there? Would a Chevrolet Pickup Flex Fan suite? I’m very cautious with the fan because it annoys me if it sounds bad.
I went with a double electric setup from Wes at Classic Heartbeat. Great setup, with a control to regulate how/when it comes on. Hooking it up directly to power so it can still run if it heats up after the engine is shut down, fairly common on hot days. Good luck with your project
If you tear off the top and bottom metal strips first. Then bring it to the local scrap yard you can get probably $35 for the copper. I just did with two old ones I had.
Copper prices are going crazy with China being the #1 exporter from Chille now.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
We redid our roof this year and I wanted copper flashing- A little over a grand for 125 feet. We did galvanized- copper ain't nearly that purty
