New Member
![]() Join Date: Nov 2004
Escutcheon problems
Is there a "trick" to installing the aftermarket escutcheon/washers that fit between trim panel assembly and the inside door handles & window cranks on the 67-71 pick-ups? We have purchased 12 in the past few weeks from various vendors and each one cracked/split around the seam found on the circumference of the part. In fact a couple split before we even had them installed in the panel. Thanks.
![]() Join Date: Feb 2001
Re: Escutcheon problems
Have had trouble getting a few of them in from time to time but never had any crack.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I had the same problem. Apparantly the aftermarket ones are made poorly. I wound up buying mine from GM. They are still available through the dealer, but only in black color. The GM ones never gave me any trouble.
Saving 1 truck at a time!
They are a little difficult to install...almost like they are just a little too big. I have not broken any but wanted to...LOL! I get mine from Truck Shop in Orange, CA. I might try the GM units however.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 04-24-2007 at 11:36 AM. |
New Member
Thank you for the responses folks. I think I will go the OEM route and see if SEM can provide a paint/dye to match the saddle color. Tx Firefighter, would you happen to know the GM part number, or where I could do some research for it? Thank you!
On the fast track to nowhere..
12338082 for 69-70, not sure if it'll work on earlier models or not.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 04-24-2007 at 04:21 PM. |
New Member
Thanks BACKYARD88. Ordered them today, will pick up on Friday. Thanks again to all who replied.
If you don't mind me asking...how much were the GM units?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
I can't remember the exact price. I ordered a couple today and I think they listed for 3 or 4 dollars a piece.
Edit: 3.07 a piece plus tax.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 04-25-2007 at 08:56 AM. |
Here's mine:
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
New Member
I do not mind. They cost me $2.48 each including tax. Had to buy a package of five for that price.
Will these work on a '68?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
