04-23-2007, 05:51 PM | #1 |
Junior Member
Testing a Factory AM Radio
I have the factory AM radio out of my 72 and also a tested working one I bought on evilbay as well as a new factory speaker because the one I had was a mouse nest. I plugged everything back in last night and can’t get either of the radios to do anything. I have followed the power wire that plugs into the speaker connection to the fuse box and it seems to be fine (no breaks). Any suggestions on how I can test these to see where my problem is?? Can I go direct from the positive post on the battery to the positive input on the radio? I don’t want to blow anything up in the process – my wife still can’t understand why I want a AM radio in the truck to begin with or why I would want to spend all my free time messing (her words) with a beat up old truck. Thanks for your help!
04-23-2007, 06:10 PM | #2 |
STOLEN
Re: Testing a Factory AM Radio
Check the fuse?
In Search Of |
04-23-2007, 06:33 PM | #3 |
Junior Member
I did and it seems to be fine - I will replace it just to be on the safe side.
04-23-2007, 06:49 PM | #4 |
member #16
Do you have a good ground to the radio?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-23-2007, 06:52 PM | #5 |
Junior Member
John - no ground - just sat the radios on the seat and plugged them in - is that my problem??
04-23-2007, 07:30 PM | #6 |
Resident Curmudgeon
Yes it needs to be grounded
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-23-2007, 09:32 PM | #7 |
First off, I think you have found my wife!
Second, yes the radio needs to be grounded. Thirdly, take a test light and check if you have power at the fuse box and and the end of the wire.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
04-23-2007, 09:40 PM | #8 |
ground and an antenna help radios work
04-24-2007, 12:51 PM | #9 |
Junior Member
Thanks to everyone who responded – I didn’t realize that they had to be grounded – I will check them tonight after I ground them and I am sure they will work – I am new at this and I have allot to learn. I would be totally lost without this site and all your help.
Thanks again – I am sure this won’t be my last question. |
