Old 04-23-2007, 06:55 PM   #1
paaw
paaw's Avatar
My stomach dropped
I pulled my rear cover off today know that I had a non posi 373 and the numbers read 14:43 stamped could gm had made a mistake cause I know I was runnin over 3000 at 65 have 275/60/15 tires
when I divide 43/ 14 I GET 307
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold
paaw is offline   Reply With Quote
Old 04-23-2007, 07:04 PM   #2
paaw
paaw's Avatar
Re: My stomach dropped
pic not turning out good but numbers are
3817779 14:43 gm 12-71 2
Old 04-23-2007, 07:07 PM   #3
arkracing
Weekend Warrior
What are your trying to ask exactly? -
if you want to know the gear ratio - you have to count the teeth on the "ring" and then on the "pinion" - divide the numbers to get the ratio.
over 3k @ 65 would probably be a 3.73 or lower (numerically higher) gear ratio.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 04-23-2007, 07:08 PM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
I run 3200rpm at 70 in my 68 swb 350/350 3.73 posi
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 04-23-2007, 07:15 PM   #5
paaw
paaw's Avatar
am I adding wrong or something I keep getting 3.07
Old 04-23-2007, 07:22 PM   #6
1969k10stepside
14:43 means 3:07,thats the gears you have....Still dont believe?Count the teeth on the ring and pinion.If there is 43 and 14,which there should be,then its 3:07 gears.Period
1969k10stepside is offline   Reply With Quote
Old 04-23-2007, 07:39 PM   #7
powell72
powell72's Avatar
Your speedo must be off.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-23-2007, 07:45 PM   #8
sodak69c10
sodak69c10's Avatar
not to butt in but how can you adjust speedo mine is off by 20mph at 65it only reads 45, i know for sure because i used gps on a clear day to check it
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 04-23-2007, 07:59 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Might find some info here for the speedo.....
http://www.transmissioncenter.net/sp...n_______va.htm
Here are the ratio numbers:
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37,9
LockDoc
Leon
Old 04-23-2007, 08:00 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
are you goin by the POS 35 year old tach?
Old 04-23-2007, 08:17 PM   #11
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Funny you should mention that. Dad's original read 3k at idle the other day lol
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 04-23-2007, 10:18 PM   #12
paaw
paaw's Avatar
going by after market tach, I would have know this I would have saved the money on the 700r and bought tires for my 20's, goint to have to count the teeth, cause it used to whine on the highway once I got over 70 with the factory trans in there
Old 04-23-2007, 10:19 PM   #13
paaw
paaw's Avatar
did 307 come factory 72
Old 04-23-2007, 10:24 PM   #14
krue
Designated A-hole!
krue's Avatar
Yeah
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-23-2007, 10:26 PM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
LockDoc
Good info
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-23-2007, 10:43 PM   #16
lukecp
Formerly yellow72custom
lukecp's Avatar
My truck with the same rear gears and tire size pulled right at 75 mph at 3,000 rpm. 65 was around 2,600 rpm, IIRC.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 04-23-2007, 11:05 PM   #17
bedsled71
bedsled71's Avatar
ive tryed to find my numbers on my axle, cant find.. can someone tell me where they are found and if the numbers are raised or not
bedsled71 is offline   Reply With Quote
Old 04-23-2007, 11:07 PM   #18
1969k10stepside
The 14:43,ect numbers are located on the ring gear....inside the differential
Old 04-23-2007, 11:19 PM   #19
paaw
paaw's Avatar
how fast should i be running in 3rd gear at 2000 rpms with these gears
Old 04-24-2007, 12:10 AM   #20
lukecp
lukecp's Avatar
Around 50 mph.
Old 04-24-2007, 12:28 AM   #21
LonghornJeff
EZEKIEL 25:17
LonghornJeff's Avatar
look on the back of your tach it might be set on the 6 cylinder setting.
68 CHEVELLE(HORSESHOE)
69 LONGHORN 396
70 NOVA 454(FOR SALE)
71 SWB 307
71 EL CAMINO 383
72 GMC JIMMY 350
87 BLAZER 350 WIW?
http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM
Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists.
The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers...
LonghornJeff is offline   Reply With Quote
Old 04-24-2007, 12:39 AM   #22
eedgell
It's the air up here
eedgell's Avatar
speedo gear in transmision? gear change in transmission?
eedgell is offline   Reply With Quote
Old 04-24-2007, 12:40 AM   #23
ckhd
ckhd's Avatar
Doing the basic math with the numbers you gave gives the following:
27" tire.
IF you have 3.07 gears, and no overdrive, you should be running approx 2400 rpm* at 65. With 700r4 overdrive, about 1700 rpm*
IF you have 3.73 gears, and no overdrive, you should be running approx 2900 rpm* at 65. With 700r4 overdrive, about 2000 rpm*
IF you have 4.10 gears, and no overdrive, you should be running approx 3200 rpm* at 65. With 700r4 overdrive, about 2250 rpm*
* All rpms are rounded
Given the information you gave, it would appear someone has swapped your gears for something in the 4.10 range. If you have something other than that, you should check your speedometer against mile posts and a stopwatch, and check your tach against a different tach.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 04-24-2007, 07:09 PM   #24
mnunn454
mnunn454's Avatar
Or that the tach has been lying to you..........
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 04-24-2007, 08:20 PM   #25
stllookn
Saving 1 truck at a time!
stllookn's Avatar
HTML Code:
I hate it when they do that...then they just stop talking to you altogether like mine did...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
