Old 04-23-2007, 07:51 PM   #1
1969burb
correcting pinion angle
Hi all! I was wondering if anyone could let me know how much correction is necessary for a 5.5 inch rear drop. I bought a cheap angle finder but my understanding is the vehicle needs to be level and have full weight on its suspension to check the current angles. theres not too much room to get under it w/o a lift. just wondering if anyone had a personal experience with this type of situation. also where is a good place to buy the angle shims for our trucks? (burbs) I have a noticeable vibration at 35-45 mph and the driveshafts have been balanced and new carrier bearing and u joints are installed, so I'm assuming it must be an angle issue. thanks for the help, steve
1969burb is offline   Reply With Quote
Old 04-23-2007, 10:29 PM   #2
powell72
powell72's Avatar
Re: correcting pinion angle
Your shake could be a tire issue. I've got a 6'' drop and don't have any issues, I figure if there were the aftermarket would include shims with the drop kits.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-24-2007, 02:24 AM   #3
leftcoast66
leftcoast66's Avatar
Ya, My axle layed on the frame when bags were dumped (I drove this way sometimes) and never had vibration issues. I would definitely look at the tires and have them balanced, and if not that I'd check your driveshaft to see if it's balanced, because those IMO are more likely.
leftcoast66 is offline   Reply With Quote
Old 04-24-2007, 08:51 AM   #4
larry may
May have a needle bearing out of place under a u joint cap, an engine mount may be dalapidated or broke,
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 04-24-2007, 09:54 AM   #5
BigTruckDriver
BigTruckDriver's Avatar
Are you using trailing arms or leafs?
BigTruckDriver is offline   Reply With Quote
Old 04-24-2007, 06:33 PM   #6
1969burb
it's a coil spring trailing arm setup. tires are new and balanced, so I'm fairly confident they're ok although I know anything is possible. I have a neighbor who developed a vibration after dropping the rear of his 1990 swb 4 inches, and it turned out to be a pinion angle problem that was corrected with 2 degree shims. that is why I'm looking into it. thanks again for any input!!
Old 04-26-2007, 04:07 PM   #7
Hart_Rod
Hart_Rod's Avatar
I've got bags (ART), c-notch and a 1 1/2 lowering blocks on mine and so far have not had any vibration issues. I think you might be able to adjust the position of the carrier bearing instead of using shims.
Hart_Rod is offline   Reply With Quote
