04-23-2007, 08:02 PM | #1 |
Later Model in dash Delco Radios
Just wondering if a later model GM Delco truck or car radio would fit in our 67-72 trucks?
04-23-2007, 10:29 PM | #2 |
Re: Later Model in dash Delco Radios
Most of the later models have a larger face plate so you would have to hack the hole to make it fit.I tried one out of a 80 camaro that looked like that and gave up cause I didn't want to cut.
04-23-2007, 11:11 PM | #3 |
Junior Member
Don't wanna hijack, but does any one make a modern radio that fits in the factory holes without cutting the dash??
frontstreetcycle on Instagram |
04-23-2007, 11:19 PM | #4 |
Professional Grade
Those mid 80's radios have terrible sound quality... I've still got that identical radio in my truck, which has been there since it was first made in 1980
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
04-23-2007, 11:20 PM | #5 |
Most vendors have am-fm radios that look like the oems. (I think)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
04-24-2007, 01:20 AM | #6 |
Zappaphile!
the moron PO of my truck had the radio on the right side in my dash (he took out the ashtray and hacked up all of the factory AC stuff to get it in there (including cutting on the dash)
I am going with a radio delete plate and just putting a satellite radio in.. goodluck but I dont think there is an easy inexpensive fix that doesnt involve cutting your dash..
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
04-24-2007, 02:46 AM | #7 |
I know i have a kenwood with cd changer controls, and a JVC, both shaft style cassette players from the late 90's that worked well when removed. They're in a box someplace but I'm not sure where. If i find them, i will post them up.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
04-24-2007, 01:01 PM | #8 |
Thanks Guys,
I was really hoping it would fit in the stock opening. I figured it would look almost stock, have FM, and not cost too much. But I will not cut the dash to fit anything. |
04-24-2007, 01:37 PM | #9 |
Self-proclaimed LED man
how far off is it? could you neatly trim the radio face itself? Im thinking that's what the PO of my truck did because the center rectangle was a little bigger than a stock radio....
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
04-24-2007, 09:21 PM | #10 |
I thought of trimming the radio too. I will have to look at one closely. I figured it was a standard size opening on most 70s and 80s vehicles.
04-24-2007, 09:27 PM | #11 |
Looking at my pictures again, I wonder if you pulled the tuning, volume knobs and nuts off if that black plastic trim piece will come off and then it would fit.
Just a hunch anyway... |
04-25-2007, 08:15 PM | #12 |
Not a bad nut after all..
It has been done: http://67-72chevytrucks.com/vboard/s...d.php?t=199806
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
05-02-2007, 09:49 AM | #13 |
Thanks for the link.
I measured the front of a 78 AM/FM Delco radio. If the black plastic piece comes off the chrome face part is actually a little smaller than the stock AM. I may still try this. |
05-02-2007, 11:25 AM | #14 |
More Cowbell....
Grandpa had already trimmed the dash to make an 8-track fit, so I made it a little more precise and slipped the AM/FM in there, but as the link above mentions (that was my pic, by the way), it was a pain in the butt. I have since switched cabs and will not do that again.
I think that radio is still in the cab if you want it. It has already been cut down in the back to clear the firewall cowl. Just shoot me a PM. I will look this afternoon and verify that it is still out there.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
