Old 04-23-2007, 08:50 PM   #1
sb69chevy
sb69chevy's Avatar
Tire wear ?
Both front tires are worn badly along the outside edge of each, but the rest of the tread looks evenly worn. What would be the cause of this? ball joints, alignment? Rears look to be fine. These tires were on the truck when I bought it, so I'm not sure how old they are.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 04-23-2007, 09:07 PM   #2
sodak69c10
sodak69c10's Avatar
Re: Tire wear ?
try this website might point you in the right direction, are you talkinbg just one outside edge each tire or or both edges of bothe tires
http://aa1car.com/library/tire_wear.htm
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 04-23-2007, 09:08 PM   #3
sb69chevy
sb69chevy's Avatar
Re: Tire wear ?
Just the outer edge of each tire. inner edge and middle of tread look fine.
Old 04-23-2007, 09:14 PM   #4
sodak69c10
sodak69c10's Avatar
Re: Tire wear ?
to camber issue. if you are around your pick-up jack up the front end and check the ball joints by pulling out on the bottom edge of tire to check for lateral movement (becareful in case the steel cords are showing) if you can't feel any looseness try the same thing on the tierod ends to check for play
,Clint
Old 04-23-2007, 09:25 PM   #5
sb69chevy
sb69chevy's Avatar
Re: Tire wear ?
Thanks. I'll have to do this. Knowing my luck, all will need replaced.
Old 04-23-2007, 09:43 PM   #6
cdowns
cdowns's Avatar
Re: Tire wear ?
every 30 or 40 years its good to have an alignment done
Old 04-23-2007, 09:47 PM   #7
sb69chevy
sb69chevy's Avatar
Re: Tire wear ?
Damn. I was on the 40-yr plan. Looks like it'll have to be done earlier than that.
Old 04-23-2007, 10:12 PM   #8
Re: Tire wear ?
I would have alignment checked. It's a good possibility (since it is a truck) they aligned it empty, but hauled a lot of heavy loads which would lower rear/lift front, thus cause wear on the outside.
Palf70Step is online now   Reply With Quote
