Old 04-24-2007, 11:01 AM   #1
shelby987
shelby987's Avatar
torque bump-stick for a 250
I have a built 250 I bought from a guy who apparently had it built to the specs. of a hot rod article years ago, but he has since lost most of the documentation. I am a little concerned that the cam is going to be more of a high end RPM cam, and be of little use in my 3/4 4x4. Can anyone recommend a good torquey cam for the 250, I am happy with my stock setup now, but it needs a rebuild, and a rebuilt engine like this with all the goodies it had was WAY less than just a basic rebuild on my stocker.
I am looking for something with good low-end torque (looking at putting 35's on to replace my 31's) but I would still like to take advantage of some of the high RPM balancing that was done on this motor.....can I have both?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 04-24-2007, 11:43 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: torque bump-stick for a 250
Call Comp Cams and see what they reccommend then see if Summit has an inexpensive version that is close to that duration, lift and separation angle.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-25-2007, 04:00 AM   #3
rwgregory
Contact Crower and ask them to build you a "Baja Beast" for an I-6. This is the modern day version of their legendary "Baja Torque Master" that has been in existance since the late '70's.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 04-25-2007, 02:32 PM   #4
shelby987
shelby987's Avatar
ttt anyone have any specs on the baja beast cam (in particular torque curves, redline, etc?).
More important, has anyone run a 250 with a setup like that and 4.10's turning 35's?
Old 04-26-2007, 02:57 AM   #5
rwgregory
Contact Crower directly at www.crower.com or you can E-mail them at info@crower.com attn: Camshaft Technical Support. They even have a worksheet you can fill out w/your info re: your truck such as weight, gearing, tire size, engine specs., intended use etc. With all of that info they can grind you a camshaft to your satisfaction.
rwgregory
305 V-6, 4-speed
