Worthless
Door seal replacement,Tips Help?
I bought some new door seals and I wanted to know if anyone has any wisdom they would like to pass on before I start.
Wrenchin & Sandin!!!
Re: Door seal replacement,Tips Help?
I put some new glue on ones on my 71 with 3m glue but they still come off. I've heard that the push on ones from GMCPauls is the way to go. I ordered a set a while ago but they are back ordered so I don't have them yet. Sorry I couldn't be more help.
Randy ![]() Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG |
![]() Join Date: Nov 2004
The trick to using the 3M weatherstrip adhesive is to put a thin coat on both items (on cab and on weatherstripping, and on both sides of each) let it cure for several minutes, then install the weather stripping. With it on both surfaces it will stick to itself, it needs to be tacky, not wet for it to work. I've done this doing several foot sections. I used vise grips to hold tricky areas (like the sharp angle at the front of the cab.)
Can't help with glue removal.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-24-2007 at 03:48 PM. |
I used black weatherstrip glue, I think it was 3M too. Put it on both sides of the weatherstripping and the door and let it sit for a few minutes, then start on the sharp upper corner of the door and work your way around. Do it in about one or two foot sections and hold it while it dries.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
Cultural Infidel
![]() Join Date: Jan 2007
I purchased the push-on type door seals from GMCPauls, worked great! Highly recommend them to anyone needing new ones.
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold ![]() 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 ![]() ![]() It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
No easy way to get the stock / old ones off. Use a hard plastic putty knife or plastic gasket scraper to help. It sucks kind of no matter what. Once you have the old one off..I used a skill knife to carefully cut/scrape the glue w/o getitng into the paint so that it was all mostly smooth. Do what people say above..but rather than holding the weatherstrip while it dries, get painter's tape at home depot. Tear off about (10) 2' strips of it, stick them on the seat/door panel so they're handy. As you apply the weather strip, you can use the tape to hold it in place as you work your way around. Let it set up good for about 15 minutes or so, carefully pull the tape and shut the door. Leave it be overnight..or I did. Perfect install, looks stock as a rock.
Active Member
I just did this, can't help with removing, mine had been off for years. I agree with Ozona, I used the painter's tape. Except I might have used a lot more than 10 pieces
3M makes a product called "Adhesive Cleaner" that sort of softens the old glue. However, you have to be very patient with it and the fumes are pretty nasty. I ended up using it on one door, but then one of the other ones wasn't so bad and I just gently scraped the residue off and applied the new glue (3M black weatherstrip adhesive--not the super version).
'72 Chevy Suburban Custom Deluxe 10, 402/TH400 |
67-72 Addict!
I used a ton of spring loaded clothes pins for the glue on type but the best way is to go with the S-10 push on weatherstrip style.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Worthless
Thanks guys for all the the help. I used all the info I could put together,and a little help from the wife,and gotter done. For sure yall was not joking about having to slam the door!!!!!!!!!(Had to try 6 times to shut the drivers door
67-72 Addict!
You can take an awl and poke air relief holes every 6" and it should help a little. Learned this trick from member Bill Athey!
laying low
![]() Join Date: Mar 2001
You can lower the window a tad when closing the door from the inside to make it shut easier then roll it up. It'll be differrent for a while.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
