Old 04-24-2007, 07:47 PM   #1
boot85
71 Chevy
sway bar off a newer truck
Are the sway bars off of the 73-79 the same as the ones for 67-72?
71 C10
72 C20
62 Chevy II 2DR HT
boot85 is offline   Reply With Quote
Old 04-24-2007, 07:48 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: sway bar off a newer truck
Yes they are. They are also larger in diameter
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 04-24-2007, 07:51 PM   #3
rage'nrat638
rage'nrat638's Avatar
excellent mod to do to your truck by the way..
you will notice the difference.
make sure you get the frame brackets..they are pop rivited on
rage'nrat638 is offline   Reply With Quote
Old 04-25-2007, 01:09 PM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
I got a right whopper off a 73-87 tow truck someone was breaking, I think it started life as a camper but it was certainly the thickest they do as standard. Got a set of new brackets from ECE (the dropped ones) new poly bushes and gave iut a coat of paint. My door handles no longer scrape the road on sharp corners!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
