Clutch pedal help
Hello everyone. I just bought a 1972 1/2 ton 4x4 with a factory 4 speed. My question is why is the clutch pedal higher than the brake pedal. I'm not talking 1/8 of an inch i'm talking 4 inches.
Thanks up front Bill
1972 K-10 L/B 4x4 Matching #'s 350 4 speed from the factory. P/S P/B 1981 GMC 1/2 L/B 4x4 one owner truck. 4" lift 2004 Dodge Cummins Diesel 4x4 Q/C S/B 1986 Dodge D150 L/B 2WD |
Son of a gun
Re: Clutch pedal help
My intitial thought is that someone must have bent it to make it more comfortable to reach or something.
Bill BEATERS ARE NEATER |
No it's not bent it's the same a the brake pedal. Theres a little rubber stopper pad mounted on a black plate. The pedal stops when it hits that. The brake pedal stops 2" before that.
Just to clarify. Do you mean higher as in - closer to you, or closer to the dash board?
'72 Blazer, A/C, tach, tilt. Not on the road at this time '87 v30 Custom Deluxe, standard cab, SRW, Utility bed '86 c10 Silverado longbed (for now) '19 ecsb, 2500, 4x4 '15 Subaru Legacy - commuter |
72 chevy
![]() Join Date: Jan 2007
My 72 C20 is a 4 gear and the clutch pedal has always been that way and my dad bought the truck new.
Ed |
I think you need more travel for the clutch than you do the brake.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Maybe someone installed a power brake booster and you lose some of the travel if the rod isnt adjusted/modified correctly.
Yes it's closer to me. It hitting the stop on the metal plate.
I agree - I just did the swap in last week and now my break pedal is stopping about 2" short of the bumper - I have the new rod adjusted out all the way but it's not quite as long as it needs to be.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
"Trucks with Class"
![]() Join Date: Jul 2000
The brake pedal on PB always hangs much lower-closer to the floor because of the short travel on PB.
It should not be adjusted up. We had a guy in here last week that installed PB, adjusted the rod out to the end and broke it off in a panic hard stop! |
PICKMUP, that is what I was told too. I always accept the advice of those who are more knowledgable than me.
I should clarify what I said too - I adjusted it out as far as I thought was reasonable but made sure there was plenty of threads still making contact so just that sort of thing doesn't happen!
Could one not make a longer rod to get the pedal back up?
#13 |
someone posted on here a while back on drilling a new hole higher up on the brake pedal bar, but ...........
I dont know if ya wanna do that. On mine, I got a coupler nut and put it between the old rod end and new booster and did gain about 1 1/2" up in travel. Now i need a brake light switch since I broke it Off!!!!!!!!!!!! |
#14 |
Well I fixed it. I took a bolt and some epoxy. I used the epoxy to install the rubber stop on the head then I installed it in the place where the rubber stopper should go and adjusted the pedal with the bolt. Now the pedal stops even with the brake pedal. A clutch pedal adjustment was in order and a test drive.
Done right the first time always Bill
