Old 04-24-2007, 11:39 PM   #1
70C10Toejam
Hellasick
70C10Toejam's Avatar
Installing my '85 MC & booster in my '70
More pics added.
This is how I fit the '85 booster in without modifying the brackets. It may not be real pretty, but it would still be acceptable for a core return.
I used some aluminum c-channel I had from some chargers. The top one is what it looks like before cutting. The other pieces are shims for the top mounting holes. They can be seen in the later pictures.
The 2nd and 3rd pics are a test fit, with the channels reversed left and right side to show how they fit and the minor bolt issue I ran into. The lower bolts could be cut down, since they no longer have to reach through the MC. I chose to leave them as is for now, later I will change for a tighter fit.
The last 2 pics are a final mockup with the MC attached. The channel pieces have been installed on their correct sides. One other change I might do later with the other full channel is to cut longer pieces and not mount the middle hole in the booster bracket and instead use the top and bottom ones. Then cutting the bottom up towards the middle mounting bolt. Don't know if it would affect the strength of the mounts, but would also eliminate the bolt interferance without cutting the original bolt down.
The booster as it is now is about 3/4 inch longer than the original booster set up, but could be closer with shallower channels. Maybe 1/2 inch without interfering with the column shift.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 04-24-2007, 11:47 PM   #2
walker
walker's Avatar
Re: Installing my '85 MC & booster in my '70
Just curious, is there an advantage to using the later model booster?
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 04-24-2007, 11:54 PM   #3
70C10Toejam
Hellasick
Not that I'm aware of...I took all my parts off a '85 chassis: spindles, calipers, steering linkage etc. Just making what I had fit, that's all. Even have 90% of the hard lines
PS box too.
Old 04-25-2007, 12:48 AM   #4
sodak69c10
sodak69c10's Avatar
i thinking about this on my truck, and was wondering i have drums on all 4 corners still and was wondering if you used the original proportioning valve of the newer one?
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 04-25-2007, 12:54 AM   #5
70C10Toejam
Hellasick
I'm gonna use the proportioning valve from the '85. The one for drum/drum is a distribution box, not really a prop. valve. Just don't have it on yet. Still on stands
Old 04-25-2007, 01:03 AM   #6
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Nice write up ans GR8 pic discription! could move this one to FAQ's section after awhile.
Thank You RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-25-2007, 11:20 PM   #7
70C10Toejam
Hellasick
If this makes someone elses work easier...all the better.
Old 05-10-2007, 11:12 PM   #8
70C10Toejam
Hellasick
Decided to add a bit more since I finished this.
First is the finished instal.
Second is the pushrod extended to fit, with 3/8 thread-all and a coupler nut.
Third is a not so good one of the factory shoulder bolt after instal, with shoulder ground down to the 1/2 inch hole in the rod.
The last 3 are of a flange-nut I practiced on to grind to fit the push-rod. Started with a 3/8 nut, had a 9/16 head, and with the flange, was similar to the shoulder-bolt.
Old 05-10-2007, 11:14 PM   #9
70C10Toejam
Hellasick
forgot the one of the installed bolt, not that you can actually see much.
just too D^$#$% hard to remove it again for a photo op.
