Old 04-25-2007, 12:42 AM   #1
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
what rearend will fit my 68 Chevy PU
ok, I have a 68 chevy truck w/a 6 lug suspension. It had a 6cylinder 3spd stick in it & i swapped it all out & put a V8 w/a 3spd auto. I have this odd feeling that my RPM's will be a tad high w/this rearend. So what other year rearends will fit or will the gears from a newer style rearend fit into my housing. thanks, joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 04-25-2007, 06:44 AM   #2
gmc67swb
gmc67swb's Avatar
Re: what rearend will fit my 68 Chevy PU
have the same problem 67 swb twisted the axel in mine...was wondering what rearends would swap out .....i have leaf springs ...finding a axel is hard...if you were closer would buy the rearend if you swapped it out....
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 04-25-2007, 11:27 AM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The 3.07 ratio is the most sought after for its high gear, but most were 3.73
File Type: txt rear ratio.txt (477 Bytes, 84 views)
sneakysnake is offline   Reply With Quote
