Old 04-25-2007, 09:26 AM   #1
BigTruckDriver
BigTruckDriver's Avatar
Will a 35 series tire be ok on a suburban?
I am buying new tires and starting to think that the 35 series tire might be a little on the small side. You do you guys running a 35 series tire think? Tires are 265/35/22 and was thinking to go with 265/40/22
BigTruckDriver is offline   Reply With Quote
Old 04-26-2007, 11:20 PM   #2
screwballl
Tonawanda 454
screwballl's Avatar
Re: Will a 35 series tire be ok on a suburban?
35 seems to be a good size for suburbans
On my R2500 3/4 ton, it uses a 235/85R16 stock size which is pretty close to the same height as a 35" if I remember right.
Using this site: http://www.miata.net/garage/tirecalc.html
it shows that the 265/35 is still a touch shorter than the 235/85R16. The 265/40 is only about 1-1/2" shorter than the 235/85....
you shouldn't notice too much difference between the two so might as well stick with what you have. The only thing you gain is about 1/2" of sidewall/radius and maybe another 1" total tire height
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
