Old 04-25-2007, 12:38 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
what adhesive to use with weatherstripping?
i just bought a set of weatherstripping for my doors on my 72 cheyenne. what would be the best adhesive to use to glue them into place? i have a tube of 3M super weatherstrip adhesive (yellow). will that suffice?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 04-25-2007, 02:55 PM   #2
grebus1
grebus1's Avatar
Re: what adhesive to use with weatherstripping?
I'd recommend the regular (not super) 3M weatherstrip adhesive in black. I've used the super before and it is made to dry faster. If you've 4 arms you can probably make it work, but the black is also an advantage in case some of the glue squeezes out behind the seal.
Also, I found it helpful to use clothespins to hold the seal in place while I was positioning it.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
