Old 04-25-2007, 02:21 PM   #1
manimal
manimal's Avatar
What should I do?
I have posted on this subject before. But now I have come to a fork in the road. Should I cut the bed corner out and replace or should I replace the whole bed side? I have a perfect LWB bed side without trim holes, then I have my 69 CSt bed side corner with trim holes. Dont know what will be the cheapest and easiest. Thanks for the input.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 04-25-2007, 02:22 PM   #2
shifty
Questionable
shifty's Avatar
Re: What should I do?
personally? I'd cut the corner. But that's just me.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-25-2007, 02:32 PM   #3
Redaddiction
LS1 Lover
I say cut the corner also
USMC
Redaddiction is offline   Reply With Quote
Old 04-25-2007, 06:43 PM   #4
manimal
manimal's Avatar
Is this hard to do?
-Lance
Old 04-25-2007, 07:06 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
can you do body work to include good welding?
I can't, I'd swap the bed side/whole bed out.
Old 04-25-2007, 10:31 PM   #6
manimal
manimal's Avatar
I can weld just fine. But I am a far cry from a bodyman.
-Lance
Old 04-25-2007, 10:35 PM   #7
lbpd719
Zappaphile!
lbpd719's Avatar
find a fender or some old body panels to practice on, then weld away..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 04-26-2007, 12:24 AM   #8
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I do some body work but I am by no means a body man.
I say replace the whole side then you know there NO bodywork to come back on ya no matter what.
IMO it would probably be faster to.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-26-2007, 12:39 AM   #9
AuggieStyle
AuggieStyle's Avatar
I say replace the whole side but im a good welder too but a much better body man I would pull that out and use my sculpting skills to fix the corner if I wanted to go cheap but I like going the best way. replace the side.
AuggieStyle is offline   Reply With Quote
Old 04-26-2007, 01:08 AM   #10
Big D
Big D's Avatar
I bet replacing the bedside might be the easiest route, but If you have access to a few metal shaping tools and a stud welder that dent could be pulled out. the metal around the taillight might be a little tricky to get right with the limited space in the cavity to use a hammer.
By reading your post I'm not sure you were going to fix it youself or have a bodyshop do it. this would run up a bunch of hours of labor to have a shop do it
You could always give it a try, If your not happy with the results put on the other bedside.
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
Old 04-26-2007, 01:13 AM   #11
manimal
manimal's Avatar
I think you guys are right. I will probably lay out the trim hole, drill,block/primer then paint the other bed side. Thanks for all the advice. I've seen it done on shortening a bed but dont really have the confidence in myself to tackle the cut and repair.
-Lance
-Lance
Old 04-26-2007, 01:17 AM   #12
RACINJASON22
GEARHEAD
Just think after you replace the whole bedside you have a nice bedside panel to use as a practice bodywork panel then. For your spare time like any of us have spare time.
Old 04-26-2007, 01:22 AM   #13
manimal
manimal's Avatar
Yeah, NO KIDDIN!! If I had a spare moment, I'd prolly take a NAP!
-Lance
-Lance
Old 04-26-2007, 01:30 AM   #14
FIVE 0
I think your on the right track with replacing the bedside. The largest hazard of welding in a new corner is heat warping. The dent could be pulled ( Time consuming ) or welded, but both take practice. I agree that you will have a nice bedside to practice on when you get done. Just my .02.
FIVE 0 is offline   Reply With Quote
