Having trouble with column and harness
I know that this is not the original harness on the column. Can someone identify it? I was looking at the harness and wiggled it out, put it back in and now my signals dont work!
Seems like my switch at the column is not working, and when I fuss with the wires that go into the harness sometimes the left and right blinkers start working. any sugestions? here are some pics |
Re: Having trouble with column and harness
Try checking continuity? Or a little grease on the blades to help make a better contact. Check where the wires are soldered, maybe a cold solder joint.... jmho
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Don't recognize that column---it is not chevy truck or van for this vintage. I suppose you could wire it in but would recommend you use either crimp connectors backfilled with silicone caulk or hard solder them to avoid poor connections. Huck
