TuTone Silverado
![]() Join Date: Mar 2007
Lowering rear/driveshaft question. Help
I had my 2.5 inch drop spindles and 4 inch rear hanger/shackle combo installed today. My mechanic told me the driveshaft is too tight now and suggested I cut it 1 inch to loosen it up. Has anyone had to do this? He says there is no give. It rides fine but he thinks it may break or something. Any suggestions? So far you guys have been right on the money about everything.
Dave 1979 GMC 2wd step side 6 cyl auto if that matters.
13 Corvette GS vert 13 Ram Laramie Longhorn 11 Wrangler Sahara unlimited 08 300 76 El Camino 67 Bel Air sedan 63 Corvette SWC 08 HD Road King Classic 68 HD Golf car |
Re: Lowering rear/driveshaft question. Help
Yoke Needs To Slip 1/2 - 3/4 Inch Out Of The Tailshaft Of The Trans. For Suspesion Travel.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
yeller
I did a 4" rear drop on mine a while back, didn't have to modify the driveshaft and had no problems whatsoever.
Did your mechanic unbolt the driveshaft and slide it in/out of the trans to inform you of this? How did he know or find out?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Flat Black, & Chrome!
We will answer your question if you show us pics of ur truck after lowering
![]() Last edited by Rc 415; 04-25-2007 at 10:00 PM. |
#5 | |
glamoros piece o' lowlife
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
Insert Witty Text Here
I didn't change my driveshaft after dropping ther rear 4 inches with drop leaves. Oddly enough, when i bought a new yoke shortly before I lowered it, the guys at the driveshaft place said, based on the wear on the yoke, that my driveshaft was too long or too short (I don't remember which). I told them I was about to lower it, and they said that would correct it.
Wierd... Slonaker |
TuTone Silverado
Did your mechanic unbolt the driveshaft and slide it in/out of the trans to inform you of this? How did he know or find out?[/QUOTE]
He disconnected it from the rear. There is no play or movement in it now. It is slammed up against the rear.
13 Corvette GS vert 13 Ram Laramie Longhorn 11 Wrangler Sahara unlimited 08 300 76 El Camino 67 Bel Air sedan 63 Corvette SWC 08 HD Road King Classic 68 HD Golf car Last edited by StepinNJ; 04-26-2007 at 09:30 PM. |
TuTone Silverado
Could this be why the driveshaft is so tight after the lowering kit was installed? The truck was originally a 3 speed trans but it was converted to a turbo 350 auto sometime ago. Could they have used the same driveshaft at that time and maybe the tightness was only noticed now?Is there a difference in auto vs stick driveshaft lengths?
Dave
#9 | |
yeller
Chris
Well guys the stock 3 speed saginaw trans. in our 76 was the exact same length as a car saginaw 4 speed, and that's the exact same length as my th350 short tail transmission.
So I say that's not the problem. If it's short tail and was 3 speed stock they are the same length driveshafts or should be anyways.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
yeller
What if his is a long tail shaft th350? How can one tell the difference...other than measuring od course.
Chris
If he has a long tailshaft 350 then I'd bet the DS was swapped from a donor truck that had a long tail 350 because it's about 3 or 4 inches I'd guess shorter then a factory 3 speed or short tail truck.
All you'd have to do would be measure or look at it, if you've seen a short tail 350 and a long tail it's easy, or you might find pics online or the 2 and compare. if you measure from the 4 tailshaft bolts to the end of the tailshaft a short tail is 6 inches I think, and then there's a 9 inch and 12 inch I think. As I said I know the stock 3 speed in our 76 was the exact same length and we used the stock DS when we ut in a 1974 camaro 4 speed saginaw transmission. Then when I pulled it from the truck and put it in my monte carlo, which the previous owner said was a th350 short tail when he had it, the saginaw 4 speed bolted right up to my crossmember and used the factory monte carlo th350 short tail driveshaft. I changed the saginaw 4 speed out for a th350 short tail and it went right in place of it.
#13 |
Parts and more parts
I had to trim my driveshaft about 1" when I dropped mine. It happens, some do and some don't.
#14 |
This will give you the different lengths:
![]() Slonaker |
