Old 04-25-2007, 09:40 PM   #1
harleyx2
73-87 crossmember and power steering question
Ok so im swapping in a 80 model crossmember and 5 lug disc brake setup in my 68 truck. Will my steering box work and if it will which pitman arm do I use? Do I use the 80 or the 68? Also will my drum brake power booster work with the 80 model master cylinder?
harleyx2 is offline   Reply With Quote
Old 04-25-2007, 09:54 PM   #2
Ram-Man
Ram-Man's Avatar
Re: 73-87 crossmember and power steering question
The steering box will bolt on but I think the lines are metric thread. The pitman arm will need to be the same year as the steering box. I am pretty sure there are different pitman arms throughout the years.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 04-25-2007, 10:18 PM   #3
harleyx2
will my stock steering box work if i just connect the 80 model steering to my 68 pitman arm.
Old 04-25-2007, 10:34 PM   #4
You can change out the fitting of the Power steering pump to match the style of the box your using. I have a 72 (SAE THread) box, but a late model serpentine pump (metric thread/o-ring line fitting. The fitting connection on the rear of the pump is a big nut fitting. I unbolted it and bolted the one from the old style SAE fitting onto the new pump, then used stock power steering lines
Old 04-26-2007, 07:25 AM   #5
harleyx2
im not worried about the pump. i already have power steering. what i need to know is if the 80 model pitman arm will fit my 68 box?
Old 04-26-2007, 12:53 PM   #6
Sorry misread your second post.
It should work. The difference in pitman arms is whether it is Power or manual steering. As long as you have a power steering arm on the box it'll match up to the later front end if it came from a power steering equipped truck.
Old 04-26-2007, 07:06 PM   #7
harleyx2
thanks for your help. what motor mount plates should i run. the newer style or the older style?
Old 04-26-2007, 08:14 PM   #8
The newer style are better. I am running them on my 70, but I still have the original drums/cross member set up. I had to drill some holes, and it does set it back closer to the firewall, But I loke the idea of the newer style mounts. Either will work though.
Old 04-26-2007, 08:52 PM   #9
harleyx2
so the old style motor plates will work with the new er style crossmember?
Old 04-26-2007, 10:08 PM   #10
They should. You'll have to drill some holes for the mounts to bolt too (just like I did to doe the opposite, new to old).
