Tips on getting the last 3/4 inch when installin motor?
OK, so I should have just pulled the trans with the motor and avoided this problem but I was being lazy. Now I am trying to reinstall the motor and I can get it to seat against the bell housing. There is about 3/4 of an inch gap and I just cannot get it to go back anymore. I know it is a bad idea to try and pull it together with the bolts so I was wondering if anyone had any advice. TIA.
1968 Chevy C10 1967 Mustang 1976 Honda XL350 2006 Victory Vegas 8-Ball 2012 Ram 1500 4x4 |
Re: Tips on getting the last 3/4 inch when installing motor?
its a matter of aligning the trans and engine level with each other..
floor jack under the transmission moving up and down and pushing back on the engine at the same time.. just make sure your converter is pushed all the way back in there should be 3/8-1/2 gap between the converter and flex plate.. and i have had to align best possible and draw things together with longer bolts before.. but..be smart about it, if it don't go very easy..somethings not right.. ![]() make sure someone did not hammer of the alignment pins and bugger them up.. be patient, take your time do it right the first time ![]() Last edited by rage'nrat638; 04-25-2007 at 11:40 PM. |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Re: Tips on getting the last 3/4 inch when installin motor?
I was just about to mention the converter ........
You could also loosen up the tranny and the cross member .... this will allow you to move the tranny a bit. Might help out.
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
The Older Generation
I am presuming auto trans, but it would be nice to know for sure.... If auto, the trans is not seated all the way into the torque converter. This will get your post back to the top and maybe someone with more transmission experience will chime in. LockDoc p.s. That's what I get for typing so slow......
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-25-2007 at 11:47 PM. |
guess I should have mentioned it is a 3spd manual and 305. I got the jack under the trans, guess I just need to play with it some more. It got dark and supper wasn't cooked yet
Next project: 1970 K10
Yeah, different answers depending on if it's an auto or a manual.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
![]() Join Date: Apr 2007
That last 3/4 is the input shaft into the pilot bushing. Are you sure the clutch is lined up? Its not generally recomended but ive done the bolt trick of which you speak. as long as you do two bolts one on each side,tightend even like you should be all right as long as it walks in with not to much effert. If it feels like your forcing it of course Id stop.
Now we really need more info..... New pilot bearing? New clutch or pressure plate? New HEI? Comon' throw us a bone..... ![]() LockDoc
Ok I guess that is what I get for assuming. Too much info is better than not enough so here goes. New intake manifold, carb, cam, lifters, pushrods, rockers, HEI, heads checked and valve job done at machine shop, all new gaskets throughout entire engine, new pilot bearing, clutch/pressure plate, and same flywheel. If anymore info is required please let me know and I appreciate all the help so far. Thanks guys!
1968 Chevy C10 1967 Mustang 1976 Honda XL350 2006 Victory Vegas 8-Ball 2012 Ram 1500 4x4 Last edited by Moneypit; 04-26-2007 at 01:10 AM. |
It sounds to me like your clutch disk isn't perfectly centered and the input shaft of the trans is hitting the pilot bushing. Use a wooden "dummy pilot shaft" to get everything lined up and then your bell housing should mate up with the engine much easier.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
Designated A-hole!
Remind me to post pics of what happens if you tighten the bellhousing bolts w/o having the t/c all the way in.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Never enough time!!
Also take a look to see if the throw out bearing is touching the pressure plate, might be holding you apart that last 3/4 inch
#13 |
OK, I think I would agree with "rwgregory". If you didn't, you should be able to rent a pilot shaft tool or clutch alignment tool at your local parts store. Use it to line up the clutch with the pilot bearing. http://www.clutchtools.com/ . If you have already done this then I think you may not have the input shaft lined up with the pilot. Sometimes you have to lift up on the front of the tranny as well as the back while installing it to line up the pilot. If this doesn't work let us know, there are a couple of other things that could cause this. LockDoc
#14 |
how many fingers does the pressure plate have ?
i dont think the 3 finger ones work with the 3 speeds
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
#15 |
Saving 1 truck at a time!
As long as you pre-aligned the clutch and pressure plate first and most important....I have found that a load leveler makes it incredibly easy as well. I have always resisted using one but found a used one on craigslist for $15 and it paid for itself on my recent engine install...15 minutes at most and no juggling of the motor...one adjustment on the tranny jack and it was done.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
#16 |
its all about the +6 inches
put the tranny in grear, jack up the rear of the truck a bit, and turn the driveshaft a tad as you try and slide them together.
Another trtuck, is to get in the truck, and depress the clutch pedal... kinda hard with the stupid z bar set up though... you could bolt it all up and then hit the pedal I guess. |
#17 |
Well work kept me out until just a few minutes ago and I'm not going to get to try anything tonight, but hopefully tomorrow after work. Yes, the clutch kit come with a clutch alignment tool which I used. The pressure plate has several fingers on it, I'm not sure exactly how many though.
I'm thinking I'm going to try a few of things you guys have suggested and if that doesn't work I will pull the trans loose, bolt down then engine then put the trans in. Thanks alot guys!
#18 |
blood type; Retumbo
or you could remove the motor mount towers. that way the engine can be lowered to be level with the trans. the it should all just slide together.
#19 |
![]() Join Date: May 2006
Hopefully the new pilot bearing has the same diameter for the transmission as the old one.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
