04-26-2007, 01:24 AM | #1 |
I have a problem
We'll after I got done tacking up the bars on the wishbone (The frame was around ride height) I let the air out and the tacks on the bar cracked. When the frame goes up and down the bars twist mabe 3/8. Is this normal? Do I just weld it up and let the bushings take all the stress? It seems like the two links on the frame twist in toward eachother when you dump it. What do you guys think.
04-26-2007, 01:26 AM | #2 |
Re: I have a problem
forhot the pics
04-26-2007, 01:40 AM | #3 |
They're binding because the front two pivots are at an angle and the rear pivot is not. If you change the front two pivots to being parallell to the one on the diff. your problem will be solved.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
