Old 04-23-2002, 11:43 PM   #1
imdarren
imdarren's Avatar
Post Rear Leaf Spring Drop?
Has anyone installed a diffrent rear shackle on the rear leaf spring to drop the back a little? Does anyone make the longer shackles? I realize you can't go much without a "C" notched frame, but I'm only looking for a couple inches. Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 04-24-2002, 04:44 AM   #2
Tim Christian
Tim Christian's Avatar
Smile
Early Classic has them that is were I got mine they are a link to them on the home page of the board.
67 GMC Stepside(UNDER CONSTRUCTION)
67 GMC Custom
67 Chevy C-30
Tim Christian is offline   Reply With Quote
Old 04-24-2002, 11:07 AM   #3
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
They are $59 new and lower you between 1.5 and 1.75" is all.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 04-24-2002, 10:27 PM   #4
imdarren
imdarren's Avatar
Post
Anyone else know of any other companies that make rear leaf lowering shackles? Darren
Washington State
Old 04-26-2002, 07:39 PM   #5
imdarren
imdarren's Avatar
Post
TTT
Hello? Anyone out there? Darren
Washington State
Old 04-26-2002, 08:45 PM   #6
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
nobody makes any that go lower if thats what you want. How low do you want to get. I have done extremely large amounts of pulling leafs for different ride heights if you want help.
72 Chevy C/10
Old 04-26-2002, 11:10 PM   #7
imdarren
imdarren's Avatar
Post
72,
Thanks for the offer. I was just wondering if there were any other shackle manufacturers. I only want to drop between 2 and 3 inches in the rear. I understand this will make it so I can't haul much in the back. That is ok with me however. Darren
Washington State
Old 04-26-2002, 11:19 PM   #8
J
J's Avatar
Post
I've got a leaf rear end also and have been wondering about this as well. 72chevylwb I'm interested tell me more. I've gotta do something until I bag it.
'72 C-10
'99 Silverado
'91 S-Dime
J is offline   Reply With Quote
Old 04-27-2002, 09:36 AM   #9
69 longhorn
Post
You can remove the flat helper,that should be worth 1/2" alone,& combined with a shackle,you should get a couple inches of drop. If more drop is wanted,you might loose 1 or 2 of the bottom short leafs(this will be experimental),& I would reccomend a set of custom slapper bars to control wheel hop. Good luck........69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-27-2002, 08:33 PM   #10
Mike C
Mike C's Avatar
Post
If you have the 2 1/2" wide springs (4x4's and I think Longhorns) then you can use the 73-87 shackles, other than that, Early Classics is it for 2 1/4". They are a great company and I would buy theirs even if they were twice as much as anybody elses.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-27-2002, 11:27 PM   #11
imdarren
imdarren's Avatar
Post
Thanks guys! Good info.
Darren
Darren
Washougal, Washington
darrengale67@hotmail.com
1972 GMC C1500 (Bone Stock)
Looking for a 72 SWB 4X4 Or 2WD Automatic with little or no rust.
Washington State
