Old 04-26-2007, 10:43 AM   #1
KFreddy
Active Member
KFreddy's Avatar
3 speed A/C???
The A/C three way switch has never worked for me in the 3rd or high position. I replaced the switch a few weeks back thinking that was the problem, didn't solve a thing. I'm hoping/ asuming that it is the relay any thoughts?
Where is the fan switch relay located in a 1972 C10?
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 04-26-2007, 11:56 AM   #2
grebus1
grebus1's Avatar
Re: 3 speed A/C???
The high-speed fan relay is on the far right of the heater/AC box inside the cab--between the kick panel and the box. I don't think you have to take out the glove box insert to get to it, but if it was out you'd be able to look right down at the relay. Replacing the relay should fix your problem.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 04-26-2007, 12:32 PM   #3
KFreddy
Active Member
KFreddy's Avatar
Re: 3 speed A/C???
Thank you for the information...
Old 04-26-2007, 12:52 PM   #4
jhow66
jhow66's Avatar
Re: 3 speed A/C???
Also make sure this is plugged into fuse panel:
(run=runs, sorry)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
