Old 04-26-2007, 11:54 AM   #1
shifty
Questionable
shifty's Avatar
Master cylinder questions
* Anyone know the bore & stgroke of the stock master cylinder on my truck (68 stepside SWB w/all drums)?
* Anyone have any luck using one of the aftermarket MC's from Summit (or otherwise) with our trucks?
* Do all master cylinders basically have the same mounting holes/footprint, or should I be careful? It looks like all MC's I've seen use a diamond shape base with two mounting holes.
I might have more questions, but this is what comes to mind right now, and I have been hunting for answers online with very little luck. Any time I mention "stroke" and "bore" i get engine related websites.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-26-2007, 02:20 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Re: Master cylinder questions
Ttt for you, watching with interest.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 04-26-2007, 03:18 PM   #3
shifty
Questionable
shifty's Avatar
I'm asking a lot of this based on what I'm figuring out as I'm adapting my hydraulic clutch for the truck. If I can get a legitimate answer and better understanding of this setup, I think I could write up a nice couple of FAQ threads on "choosing a brake MC" and "picking up a clutch MC"/"installing a hydraulic clutch into our trucks", which I'm sure would benefit a lot of people.
I'd love to be able to go to Summit and get a $50 Wilwood or other MC with integrated resevoir to use for both my hydraulic clutch *and* for my brake system.
I'm just having a bit of an issue tracking down stock stroke/bore numbers and fitment for the 67-72 pickups.
I understand you can use basically any MC that will bolt up to the trucks as long as the BORE x STROKE is greater than or equal to the stock setup. The tough part is finding out what that/those values are, I think?
