easy hardtop removal
any suggestions on a 1 man removal of the hardtop.
How much does the top weigh? can i set up a hoist in my garage to be able to put on and off? how can i strap it up so that it is secure. Newbie and I want to be able to take on/off because I live in Northern California. some days are beautiful and other days are cold in the summer. want to be able to have the option. ![]() |
Re: easy hardtop removal
SKINNY TIRES RULE!
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Post Whore
![]() Join Date: Feb 2000
This is so on my mind right now and this post pops up! Can't beat that. Had to laugh this morning as I was getting ready to take the kids to school - I opened the passenger door and noticed the side of the top move, pressed against it and I think all of the bolts on that side of the top are gone! It's just begging to come off
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I just use some heavy duty screw hooks (Like for hanging bicycles) into the rafters place 2x4s under the hard top. Then use ratchet straps around the 2x4 and hooks and ratchet the top up a coulple of inches on each end until it is high enough to drive the truck out from under. Easy one man job.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
thanks for all the great information
The LuvShack Garage
I used 2 1" ratchet straps, 1 4" ratchet strap, a low hanging branch, and a 250 4Traxx
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
No,I DON'T have Tourett's
If you have room, I set four posts in the ground about 6" wider than the blazer and spaced so they'd catch the four corners of the top (where it sits on the bed rails. Back the blazer between them, loosen the top, slide 2X4" between bed rails and top, and hike each corner up about 4", attach 2X4"s to posts, and drive the blazer out from underneath. I dropped the top back down so it wasn't so high. Installation of top is the reverse.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
#9 | |
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
Cstanley, that seems to be the bad part about rachet straps, they only rachet one way, it's a free fall the other...
How about a come along, instead...... J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Post Whore
When I lifte mine I used the 2 2x4 method with cables and my comealong and just when I started to lift the top I noticed that I had one of the 2x4's running through the rollcage - whoops, that won't work, had to move that 2x4 to the very front of the top and of course the seats were in the way so I had to get the front of the top lifted a bit then put the 2x4 into place. Had to laugh at myself when I saw my original plan just wasn't gonna work.
Definitely going to fine tune my setup based off of the design that BobbyK uses.
#12 | |
Just need a couple more parts.
This year I am using the method Bouncy listed.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 Last edited by VinceY; 05-04-2007 at 01:46 PM. |
#13 |
SKINNY TIRES RULE!
The method I use works great. I remove and put the top back on completely by myself. I do have to remove the rear seat and the spare tire to drive out from under the hanging top, but that could easily be solved by lifting it just another inch or so.
Best of all, I think It cost me less than $10.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L Last edited by bouncytruck; 05-04-2007 at 02:53 PM. |
#14 |
Sofa King. We, Todd, Ed.
Low tech, low buck, easy one man job. I just back the truck up to the permanently mounted rear cross bar, slide the top back a foot and set it on the crossbar. Then I slide in the moveable front crossbar and drive the truck out from underneath. Takes 5 mins!
AND I can park my lowrider beater station wagon under it. ![]()
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
