Got earplugs?
Big Block
I am finally parting with my engine.
It is a 402 big block with a long list of aftermarket parts. Runs perfectly. Bottom end was rebuilt about 500 miles ago. New bearings all around. I will consider selling individual parts if the whole engine does not sell. Any more info let me know. Here's the list. Cloyes Billet Steel Hex Adjust Timing Set ARP Rocker Arm Studs 7/16" ARP Rocker Arm Perma-Loc Nuts Lunati Voodoo Camshaft Kit 284/292 .572/.590 System 1 Pro Street Fuel Filter 06-AN Ends Holley Electric Fuel Pump "Blue" Jone's Racing Products Billet Aluminum Alt. Bracket Billet Aluminum Crankshaft Pulley Speed Pro Powerforged Pistons Ring Kit 10.81:1 CR w/ 107cc Combustion Chambers New 168 Tooth Flexplate Moroso Blue Max 8mm Spiral Core Over Valve Covers Melling Hi-Volume Oil Pump Melling Screw In Pick-Up MSD Blaster 2 Coil MSD 6-AL Jeg's Harmonic Balancer 7" Internally Balanced Cloye's Quick Button Timing Cover MSD Billet Distributor New Bronze Valve Guides CSI Billet Aluminum 360 Swivel Thermstat Housing CSI Electric Water Pump Eagle I-Beam Steel Rods Barry Grant Speed Demon 750cfm. Mech. Secondaries Barry Grant Fuel Line Stainless, Filtered Edelbrock Victor Jr. Intake Crane Cams Gold Race Billet Aluminum Roller Rockers Comp Cams Hi-Tech 4130 Chrome Moly Pushrods 3/8" Comp Cams Pushrod Guide Plates Crane Cams Valve Springs/Retainers/Locks Matched for Cam 402 Block .030 over New Rod, Main, Cam Bearings Stock Iron Heads, 113cc. Combustion Chambers ARP Bolts: Intake, Oil Pan, Flexplate, Harmonic Balancer Complete engine, fuel delivery, and ignition system. $4000 obo Thanks for looking
1968 GMC Original A/C, bucket seats, PS,PB 396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression Alltogether 411HP and 446ft/lbs Dana 60 w/ 3.54 gears Turbo 400 tranny Why would you have anything other than a big block? HAHA |
