Radiator Issues
i put a new larger radiator in my C-10 (350, no a/c, manual, no over flow res).
when i fill the radiator all the way up and drive the truck, the radiator will spill out some of the fluid. thats understandable. however it spills out so much that when i idle (ie. at a stop light) the engine will start to run hot. when i start riving again the temp immediately drops to normal. Can anyone explain to me what is happeneing and why? the hoses are new and the thermostat (190) is new. |
Re: Radiator Issues
Are you sure your temp gauge is functioning properly? Have you tried just filling it approx. 3/4 full to see if it does it? What concentration of antifreeze/water are you using? Out of curiosity is your overflow tube attached to radiator?
R.I.P. Killer 71 10/26/07 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Re: Radiator Issues
My understanding is that if you have cooling issues when driving, then its a rad size issue, but if you have cooling issues at a stop, then its an flow issue (no shroud, wrong fan, airleakage around the rad, etc.). Is the coolant spilling out at a stop because its boiling or is it spilling out & causing it to boil? If its the latter, then you could have a rad cap issue too. I hope this helps.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
Questionable
Re: Radiator Issues
I would think it was a cooling issue - not pulling enough air through the radiator.
i suppose it is also possible that your thermostat is shot, pulley for the water pump is shot, or the impeller is busted on the water pump?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Re: Radiator Issues
Shifty, if it was the stat, pulley or pump, wouldn't he have problems at speed too? All of those things mean he's not getting the right amount of water in the motor which would cause problems all of the time, not just stopped.
I would think it would have more to do with either too small of a radiator or airflow issues. I could be wrong, my wife tells me I am all the time. Do you have a shroud on it, what kind of fan, clutch or flex? Ronnie
1968 C10 Stepside 396 bored .030 TH400 |
Re: Radiator Issues
i think it is radiator size too. or the cap i have always questioned it. i am going to replace it tonight. i am running stock fan, clutch.
the shroud is stock but the radiator is only slightly taller and wider but its much thicker. 4 core. it doesn't always over heat. only after it has pushed enough coolant out. the question is why is it pushing it out. the over flow tube is connected to the radiator. regardless of how full it is, it will overflow until it is too low, then i am stuck in traffic reving the engine to move coolant through. i am not sure that it is boiling so much as just pushing it out. i read in another post about using a heavier cap (15psi) if you dont have a resevoir. ?? Last edited by dznucks; 04-26-2007 at 03:51 PM. |
Re: Radiator Issues
I would think a 4 core would be plenty big enough, is it in good shape? What's the engine specs?
Re: Radiator Issues
How low is what you think is to low? It should not be full all the way up. And 4 core is more than plenty unless you are running lots of 4x4 climbs or something.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
![]() Join Date: Aug 2004
Re: Radiator Issues
I bet it's your cap, how low does the level go after you let it cool off when it has overheated? It should be within 4 inches of the cap when cold. I think there's marks on the tank to show the full level.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Re: Radiator Issues
replace your cap, have an overflow, and make sure the clutch on your fan is working. Overheating at stops is an airflow problem, (almost) always. You don't have the air moving thru it to cool the coolant, because your engine speed is low (fan speed low, or with a bad fan clutch, the fan could be spinning super slow with little force) and you have no mph pushing air thru. This can be aggravated by having a cap that allows bypass at too low of a pressure. The overflow will also help, as it catches what boils out, then when the coolant cools off again and contracts, it will vacuum in coolant to keep it topped off. Make sure that there are no leaks near the cap though, the rad could have pinholes that let boiling coolant out, and then draws air back in when it cools off.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. Last edited by martinkh; 04-27-2007 at 03:21 PM. Reason: added the almost in front of the always! |
Re: Radiator Issues
thanks martin. i got a new cap, going to get a clutch. i know its old and it makes sense that it cold be slipping more.
i got to looking at the radiator and i noticed that the bottom rad. hose is twice the diameter of the top. i wonder if that has anything to do with it. combined with a larger capacity than the system needs??? its was new when i put it on a year ago, but its an odd size gm radiator for a heavy duty work truck or van. Last edited by dznucks; 04-27-2007 at 06:44 AM. |
Re: Radiator Issues
the hose sizes from top to bottom are gona be different, and you could always 86 the clutch and run a solid fan, let us know when you get it figured out and good luck with it
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#13 |
![]() Join Date: May 2006
Re: Radiator Issues
Might want to check your belt pulleys. They may be worn and the belts are touching the bottom of the groove and slipping.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
#14 |
Re: Radiator Issues
i belive it was the radiator cap. the new cap was alittle bit longer than the old one, not even 1/8". so i suspect the cap was not sealing at all in the radiator and fluid was being pushed straight out of the over flow tube. looks like the spring is worn, its been with the truck as long as i have had it. may be original.
with no pressure to containt the proper fluid level it was over flowing too much fluid causing it to overheat when idling. thanks for the help guys. Last edited by dznucks; 04-27-2007 at 01:05 PM. |
#15 |
Re: Radiator Issues
What are the dimensions of the radiator?
