Old 04-26-2007, 04:12 PM   #1
kevncar
Active Member
kevncar's Avatar
remove front bags without poppin B.J.?
For those of you running bags, plates and cups on the front. Can you air down, jack up the front end and take the bags out without seperating ball joints? Just curious.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 04-26-2007, 05:20 PM   #2
jimmydean
jimmydean's Avatar
Re: remove front bags without poppin B.J.?
Maybe. It would be close and a bit of a pain in the ass. If my cups were cut, I think it would clear without issue.
I recall someone talking about the cup popping out when they jacked the front up. If that happens, unbolt the plate and slide.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-26-2007, 06:03 PM   #3
Alvin
Never Done?
Alvin's Avatar
On my set-up (running schrader valves on my rolling chassis), if the front bags are deflated and you jack up the front end, the bags stay in their deflated state; with the cup hanging on the bottom well above the lower a-arm. I wouldn't think you'd have trouble getting the plate unbolted and out.
*edit - Jimmy Dean! What's with this "SOLD" business in your sig? Did I miss something somewhere?*
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 04-26-2007, 06:42 PM   #4
69face
69face's Avatar
i havent had a problem getting min out with a jack and stands either
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 04-26-2007, 07:32 PM   #5
jimmydean
jimmydean's Avatar
[HIJACK] Yes, sad but true. I sold the truck in my avatar and purchased a 71 K20 Super Redneck Edition. As much as I loved it, a 2WD does not fit my needs. Pics and stats of the K20 to follow soon (in the 4x4 forum). It's in sad shape, but holds a lot of promise. As much as "Daisy" will be missed, the wife is a great deal happier with "Ugly Betty"
I also purchased a Toyota Supra (to fill the performance void), but that's for another forum. [/HIJACK]
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-26-2007, 10:30 PM   #6
pissonNOS
senior member
pissonNOS's Avatar
glad to hear this ive been wanting to cut my cups but didnt want to really take it all apart again i figured if i can remove the bump stops with out popping a bj then i could
69 GMC bagged
pissonNOS is offline   Reply With Quote
