chevelito
Hi guys,
Well, looks like I'm gonna do a frame up. The bed is ready to be lifted off and will start work on the front clip and cab soon. I will be sending the frame to be dipped. My question is, how far do I break down the frame? Do I take off the front crossmember? How about the tranny crossmember? (I hope I'm getting the terminology right. Anyway, I dont want to take off more than I need to. Thanks alot, jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
Progress = 0%
If it were me, I'd take it ALL apart (and I did on mine) .... but I'm kind of anal like that
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
chevelito
hey thanks for the heads up. I am going with bags and was doing a search on the board. I'm still in the planning stages for the bags though. Looks like I'm notching too.
Soo, Looks like the front crossmember and tranny crossmember will come out. I think I'll leave the other braces though. thanks, Jay
Just out of curiousity, how do you get the cab off the frame? It HAS to be too heavy for a couple of big guys to lift (unlike the bed). Is this something that can be done without a specialized lifting hoist?
Just curious. |
registered IWATA user
when i took aprt a 69 to get teh frame we just used a chainfall over a beam in the guys shop, put a strap under the roof, but that bent the drip rails, but that cabwas crap anyway, we gave it to a scrap yard, there a way to do it with 4 people and some boards i think, but i'll let someone tell you ythe right way to do that
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
Got Caddy?
hey mike
I just took my cab off this weekend and it is heavy. So i used an oversized swing set and lifted it straight up, here's a pic.
Jim ![]() |
the cab is 560 pounds with only the windshield in it nothin else.me and a friend managed to lift it ourselves but it is very awkward it wants to fall onto the firewall.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Progress = 0%
3 friends and a 12-pack of your favorite brew is all it takes
Four of us lifted my cab then walked it to the front of the frame and sat it on a dolly that I made out of 2x4's. The cab had all the glass, doors, seat, steering column and wheel, heater, and a dozen or so beer cans. This was just before we took it off.
Cantankerous Geezer
On the frame dip, I would remove anything that is bolted on. I wouldn't drill out rivets on anything that doesn't have to come off.
On the cab removal, first strip the cab of seats, doors, glass, steering column, etc to lighten the load. Then you have some options. Four guys can then lift it. It can be raised with a floor jack and a large piece of plywood to spread out the load as much as possible. The cab can be lifted with a hoist if you use a spreader bar and tie into the door hinges and latch bolt holes. A friend and I put the cab back on his 52 using a floor jack and blocks. We had to sit the cab on blocks on the frame to move the jack around the crossmembers, but it only took one of us to run the jack, the other to steady the cab. ![]()
Fred There is no such thing as too much cam...just not enough engine. ![]() |
I used a shop crane (engine lift) with a strap around the bottom. The picture shows it after we let it lean over the front, but it is no problem to balance it on the strap, as you are moving it.
69 SWB LT1/4L60E www.classicplace.com |
I took my frame almost all the way down including some rivets that held a little reinforcement bracket just in front of the rear end if I remember right. I could see crud in there and it bothered me. Then after sandblast and primer I bolted them back in with grade "8" bolts.
#13 |
chevelito
ok...so whatever is bolted down, then it comes off. Whatever is riveted stays.
thanks, jay
#14 |
Almost Satisfied
![]() Join Date: Mar 2002
A couple of things to keep in mind. If you have a steering stabilizer bar you will want to grind off the bottom rivets of the first crossmember so that you can bolt your lowering brackets to them. On the back you will want to take off the stock shock brackets. Of course all of this depends on how low you go! I'm doing a 4/6 drop and these are a couple of things that needed to be removed prior to powder coating the frame.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#15 |
chevelito
when you say stabilizer bar, you mean sway bar?
Thanks guys... jay
