Old 04-26-2007, 08:33 PM   #1
brawley
Easy Does It
brawley's Avatar
60-66 chevy parklights
I have a 1965 chevy C-10, I was wondering whats the easiest way to keep the parklights on when my headlights are on. I've heard of using a scotchlock-or quickconnector and tie in the #4 post To the #7 post in the headlight switch, does this sound right? Any other ideas? Thanks.
brawley is offline   Reply With Quote
Old 04-27-2007, 12:10 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: 60-66 chevy parklights
Yeap the rear tail output to the front parks...
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-28-2007, 11:46 AM   #3
slammed1966chevy
slammed1966chevy's Avatar
hmm this is good that i cam acorss this i want to do it to mine is it hard to do it ?
slammed1966chevy is offline   Reply With Quote
Old 04-28-2007, 12:00 PM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Basically the wire that feeds the rear taillights must be connected to the front parking light wire
The front parkling lights only come on in the middle position of the headlight switch....but the rears come on regardless of position. So by connecting the two together, you will get front output as well.
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-28-2007, 09:10 PM   #5
19GMC63
19GMC63's Avatar
so what is the purpose of the scotchlok? Aren't you just connecting 4 wires together?
19GMC63 is offline   Reply With Quote
Old 04-29-2007, 04:47 PM   #6
Captainfab
60-66 Nut
No you're connecting two wires that are parallel to each other. By using a Scotchlock' you're just creating a connection between the two wires. I might add that if you use a Scotchlock, you'll need to cut out the tab inside so that you can use it on two continuous wires. At least thats they way I've done it.
Old 04-29-2007, 05:15 PM   #7
19GMC63
19GMC63's Avatar
I'm still confused, sorry. lol
So your taking the brown and purple wires, parallel to eachother, and "fusing" them together, right?
So why can't I just double them up in a butt connector?
Old 04-29-2007, 06:34 PM   #8
brawley
Easy Does It
brawley's Avatar
thanks for the replys, I'm going to try this soon, looks like the brown and purple wire are what to tie together.
Old 04-29-2007, 08:30 PM   #9
19GMC63
19GMC63's Avatar
ok, butt connector works, no need to buy one of them there fancy connector thingys.
Old 06-03-2007, 04:33 AM   #10
LILRED66
LILRED66's Avatar
Here is the method I used to make the park lamps come on with the head lights. It is the short red jumper wire with the black connectors. I like the Scotchlock snap-on connector like CheifRocka used, however I only had the black connectors in my eletrical connector arsenal. For some reason, I had to use the purple and blue wires to make it work. Perhaps the previous owner had done some shade tree electrical modifications. In any event, it works and I like to look at night better than just the head lights.
Good luck with your modification.
LILRED66 is offline   Reply With Quote
Old 08-07-2007, 11:59 PM   #11
brawley
Easy Does It
brawley's Avatar
I tied the purple and brown #4 and #7 post. The park lights come on with the headlights but now my turn signals will not come on when the headlights are on, any ideas how to fix this? thanks.
Old 08-08-2007, 09:10 AM   #12
63 & 64 Bowties
and a few others
just a wild guess...bad ground? does the "brightness" on the parking lights change at all with the flasher?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 08-09-2007, 09:11 PM   #13
brawley
Easy Does It
brawley's Avatar
The lights are bright and the rear signals come on, but for some reason the front lights do not blink? Do I need diffrent bulbs? Where would I have a bad ground? thanks.
Old 08-10-2007, 07:15 AM   #14
63 & 64 Bowties
and a few others
another guess, but could someone have rewired your front park lights? when you have just the park lights on, are they brighter than the flashing turn signal with lights off? that could mean that the filaments are wired backwards (bright side to park lights, dimmer side to signals.)
Old 08-10-2007, 05:37 PM   #15
19GMC63
19GMC63's Avatar
they still should blink though, regardless of what filament is being used.
So when the parklights are on, and you put on the blinker, does the park light on that side get brighter and stay solid, or do they not get brighter at all? Do your indicators in your dash blink?
edit: it could be a bad ground, are your parklight housings rusty?
Old 08-11-2007, 02:07 AM   #16
salazar44
65 - Chevy C10
salazar44's Avatar
What harness are the brown and purple on?
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 08-12-2007, 12:17 AM   #17
NF65Fleetside
NF65Fleetside's Avatar
You sure about that? I think all blinkers are dual filament since they are dual purpose bulbs, unless the single filament is in a degsinated blinker socket right?
NF65Fleetside is offline   Reply With Quote
Old 08-12-2007, 08:19 PM   #18
raiden7800
Straight "6" Shooter
raiden7800's Avatar
If the bulbs are in backwards, the bigger filament will be so bright that you cant see the smaller blinking. If you try turning the bulbs around, you may find that they do blink, and pretty brightly at that because they will be utilizing the bigger filament.
1966 LWB 292 I6 & Granny Low
If you listen intently, you can hear a FORD rusting in the distance.
My LUG NUTS take more TORQUE than your HONDA makes!
raiden7800 is offline   Reply With Quote
Old 08-12-2007, 09:32 PM   #19
19GMC63
19GMC63's Avatar
Its impossible to put parklight bulbs in backwards. One slot is shorter than the other, and one nipple thing on the bulb is further up the bulb than the other.
Old 08-13-2007, 11:24 PM   #20
brawley
Easy Does It
brawley's Avatar
I used a quick connector on the headlight harness-I connected the brown and purple wire together,this causes the parklights to come on with headlights, However now they don't blink when I turn my turn signals on. The signals in the dash come on and the rear lights blink.The front parklights are on they do not get brighter or dimmer they stay the same. everything else works fine. Any ideas? thanks.
Old 08-13-2007, 11:55 PM   #21
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
OK..I know this was asked already....but
When you turn on your headlights, are the front P.L. lighting up the running light or the brighter turn signal filiament ??
How about when you turn the headlights off...does it flash at all ?? Is it dimmer then when the HL are on with no turn signal ??
Have you checked the harness plug at the firewall with a test light ??
With the headlights on you should have only one hot lead at that connector.
Then check you turn signals....LT should flash on side.....and RT should flash the other connector.
This shouldn't that big of a deal to figure out. Start at that connector, and let us know what you got.
And also, if the sockets are worn out, you can insert a bulb backwards, BTW.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-13-2007, 11:58 PM   #22
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Also...did everything work correctly before all of this ??
You think you might of bumped something loose under the dash ??
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-16-2007, 12:03 AM   #23
brawley
Easy Does It
brawley's Avatar
thanks for the replys, the parklights work when my headlights are off, but when I turn my headlights on the get brighter and do not blink. Did I do the right thing connecting the purple and brown wires in the headlight harness or is this something else? thanks.
Old 08-16-2007, 09:00 AM   #24
63 & 64 Bowties
and a few others
you may want to check the pigtail in behind the socket. i can't remember if the front lights are the same as the taillights, but i know with taillights you can plug the pigtail in backwards. the bulb won't go in backwards, but the short pigtail that comes off the socket is reversable on the taillights, and maybe front parks too.
