04-26-2007, 09:55 PM | #1 |
idahospud
Question about a 68 longbed 4x4
Ok I have been looking at a truck that has me confused. Here is the deal it is a 1968 3/4 ton 4x4 4 speed big block sofar so good but here is the funny part the vin on the inside door and glovebox match and the vin is ce248z159939 the truck is beat to crap so I'm guessing if it was originaly a 2 wheel drive it was a long time ago.This is a 2 wheel drive vin is it not?
71 cheyenne fleetside shortbed 2003 gmc crewcab duramax SLT 4x4 96 chevy tahoe Last edited by gmman456; 04-26-2007 at 09:56 PM. |
04-26-2007, 10:05 PM | #2 |
Re: Question about a 68 longbed 4x4
If the door is this number then it's a 68 3/4ton 2WD. They might have swapped cabs in the past...
Chassis Designation (1st digit) C= 4x2 K= 4x4 Engine Deisgnation (2nd digit) E = V-8 Gas S = Six Cylinder Gas GVW Range (3rd Digit) 1 = 1/2 Ton 2 = 3/4 Ton 3 = 1 Ton Model Code (4th Digit) 4 = Pickup with Cab and Bed Model Year (5th Digit) 7 = 1967 8 = 1968 9 = 1969 0 = 1970 1 = 1971 2 = 1972 Assembly Plant A = Atlanta B = Baltimore F = Flint J = Janesville N = Norwood P = Pontiac S = St. Louis T = Tarrytown Z = Fremont 1 = Oshawa Vehicle Serial Number 100001 = 1st Unit Built 1967-1972 Model Number Codes (The Model Number is located on the inside of the glove box door.) Example: C E 1 09 9 34 J 100001 Chassis Designation (1st digit) C = 4x2 K = 4x4 P = Forward Control Engine Deisgnation (2nd digit) E = V-8 Gas S = Six Cylinder Gas GVW Range (3rd Digit) 1 = 1/2 Ton 2 = 3/4 Ton 3 = 1 Ton Cab To Axle Dimension (4th Digit) 07 = 42"-47" 09 = 54"-59" 10 = 60"-65" 12 = 72"-77" 13 = 78"-83" 14 = 84"-89" 15 = 90"-95" Model Year (5th Digit) 7 - 1967 8 - 1968 9 - 1969 0 - 1970 1 - 1971 2 - 1972 Body and Brake (6th Digit) 02 = Flat Face Cowl 03 = Cab 04 = Stepside Pickup 05 = Panel 06 = Suburban 09 = Cab, Platform, and Stake Rack 12 = Windshield Cowl 16 = Suburban (Tail and Liftgate) 26 = Custom Suburban (Panel Rear Doors) 34 = Fleetside Pickup 35 = Foward Control (Square Front) 36 = Deluxe Suburban (Panel Rear Doors) 42 = Forward Control Chassis 45 = Forward Control Panel (Round Front) Assembly Plant A = Atlanta B = Baltimore F = Flint J = Janesville N = Norwood P = Pontiac (GM Truck) S = St. Louis T = Tarrytown Z = Fremont 1 = Oshawa, Ont., Can. Vehicle Serial Number 100001 = 1st Unit Built
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-26-2007, 10:31 PM | #3 |
idahospud
Thats what I thought.But the cab supports are in really bad shape so I don't think the cab has been swapped.I'm thinking they turned a 2wd into a 4wd because everything else seems
correct.Is there any other way to tell if the frame is a 2wd frame?
71 cheyenne fleetside shortbed 2003 gmc crewcab duramax SLT 4x4 96 chevy tahoe |
04-27-2007, 04:14 AM | #4 |
are the front spring mounts bolted or riveted to the frame bolted means they have beenchanged at one point there is also a vin on the left front frame on top jusr to the rear of the stearing box
common sense isn't so common anymore |
04-27-2007, 04:26 AM | #5 |
try and find the vin number on the frame and compare it, but i dont think just because the cabsupports are screwed up means doesnt mean it wasnt swapped
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
04-27-2007, 05:40 AM | #6 |
They did not make Big block 4x4s is what I have always been told, so something has been definitely juggled with, body, drive train or the 4x4 stuff.
04-27-2007, 07:05 AM | #7 |
thats what ive heard to
04-27-2007, 07:19 AM | #8 |
yes no bb 4x4.
04-27-2007, 03:58 PM | #9 |
idahospud
No not screwed up just worn out and trashed.So if it was a swap you would think they would have gotton new ones,but then again the truck's only saving grace is that it has a big block and its 4x4 the the truck is trashed,and they want $2 grand for it.
05-03-2007, 01:45 AM | #10 |
That's a darn shame, I picked mine up for $500 bucks right around the corner from you.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
05-03-2007, 01:47 AM | #11 |
but if infact it was swapped then it couldve been done long ago enough for them to wear out
