04-27-2007, 12:15 AM | #1 |
yeller
wiring harness cover, my turn...pics inside
OK, with all this talk about fuse block/wiing harness covers...and seeing some others good looking covers here on the board, I decided to get my overdue envision out of my head and onto my truck.
I am running a 73-87 Painless kit, that bolts to the firewall with a couple 1/4-20 nuts and bolts. I went to the hardware store and purchased longer 1/4-20 bolts, nuts, couplers, and allen head stainless fasteners. The cover is made out of metal, dimensions are 4X4X2.5. I notched the bottom and top for wire exiting. The openings will be lined with rubber, the wires will be covered in loom, and the box will be painted body color. I purposely left the box "floating" off the firewall, as I did not want metal on metal contact and a scratched paintjob. Hope you guys like it, it was very easy to build and makes a big difference IMO.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-27-2007, 02:11 AM | #2 |
Re: wiring harness cover, my turn...pics inside
really nice, make about 50 of them and sell them on ebay.....
stone sends... 78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201) 06 Dodge Charger Daytona R/T 05 Suzuki GSX-R 1000 |
04-27-2007, 06:39 AM | #3 |
STILL PLAYS WITH TRUX
That looks real good jeff and it will look even better once it's painted to match.
04-27-2007, 08:59 AM | #4 |
Slots go on anything!
Jeff, what about using some black door edge guard to protect the paint? That way is will look finished, and not rub the paint.
04-27-2007, 11:36 AM | #5 | |
yeller
Also, that area of the firewall is not perfectly flat, it angles slightly...if I were to sit it flush with the firewall, then it would look angled too...that would bug me. Anal, I know.
04-27-2007, 12:00 PM | #6 |
The Crazy Machanic
sweet idea. i like the floating idea with the screw in design. Having it have it own mounting spot make life a lot nicer then having to screw into the fire wall.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
04-27-2007, 12:51 PM | #7 | |
I designed mine the same way, to float above the firewall. I used the e-brake bolts to mount mine since I didn't have those bolts like your painless kit has. -John Last edited by jr2; 04-27-2007 at 12:53 PM. |
04-27-2007, 04:32 PM | #8 |
Until Seventy Times Seven
It's looks really good, Jeff.
Should blend into the firewall once you get the yellow on it. (Hmmm, the Painless kit looks like it has enough slack in the wire to recess the fuse box into the cab about an inch or even more. Then using a template like yours, build a shallow box. And, top it off using SS button heads.) Good job.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
04-27-2007, 05:24 PM | #9 |
Right in front of you.
Simple, clean, effective.......great work!!!
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
04-27-2007, 05:54 PM | #10 | |
yeller
Thanks for the compliments guys, appreciate it.
04-27-2007, 06:03 PM | #11 |
nice job jeff,when i started that post i never dreamed there would be that much intrest in such a little thing.
" Never look up a dead dogs butt." |
04-27-2007, 06:05 PM | #12 |
WAY TO GO BEN!! Now see what you started
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... |
04-27-2007, 06:10 PM | #13 |
yeller
You forced me off my butt to build this. Been thinking about it for a while, but you gave me the kick I needed.
04-27-2007, 07:04 PM | #14 |
'lox'
So, the painless kit comes with the stainless box?? I just finished wrapping all my wiring and your thread will make the perfect ending. Thanks for sharing..
04-27-2007, 07:24 PM | #15 |
no,no,no no man,you gotta read from the top(just kidding ya) . these are highly customized,works of art.one off boxes.bigblock 73,j.r,and me, the boatpuller. have all fabbed and posted pics on covering up this eye sore.there's none available on the aftermarket that we know of.
04-27-2007, 07:33 PM | #16 | |
04-28-2007, 03:12 AM | #17 |
>130dB Moderator
Hmm... maybe I should do that too...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
04-28-2007, 10:02 AM | #18 |
Happy to be here
Nice work Jeff. Your going to force me to build one too.
04-28-2007, 11:51 AM | #19 |
yup,your eyes are gonna focus on that spot till your forced to "make the move."
04-28-2007, 11:58 AM | #20 | |
04-28-2007, 02:46 PM | #21 |
yeller
It was very easy to install, but like you said, I had a clean slate to work with. I am not so sure I would attempt it on an assembled truck...lots of stuff in the way with lots of stuff to remove in order to install it.
But, if you are doing a body off resto like me...then I wouldn't think twice about it...do it!
04-28-2007, 02:50 PM | #22 |
Dark Heart Motorsports
I bid $1...
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
05-02-2007, 02:42 PM | #23 |
05-02-2007, 02:58 PM | #24 |
typical ebay seller! does it come with a $318.00 cash money rebate?
05-02-2007, 03:11 PM | #25 | |
But if you SIGN UP with my online club I'll give you a 50% dsiscount. All we need is a credit card # your social security # and bank account # and we'll deposit the discount in your account for accountability
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... Last edited by jr2; 05-02-2007 at 03:13 PM. |
