Old 04-27-2007, 02:41 AM   #1
jimmydean
jimmydean's Avatar
ORD vs. Sky Manufacturing flip kit?
They are only about $20 difference in price, but the ORD kit looks a little more stout to me. Anyone ever compare the 2? Pros or cons of either?
I'm looking to ditch the 4" blocks I have.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-27-2007, 02:17 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: ORD vs. Sky Manufacturing flip kit?
dirtyLarry just got the ORD kit a month or so ago. I can say this, the ORD stuff is very beefy. Nice welds and grade 8 hardware. I haven't seen the Sky kit in person, so I can't comment on it's quality other than what I've seen in pics on the web.
It's your call, but if I needed to replace the shackle flip I put on mine, I'd spend the extra dough for the ORD setup. It's worth it.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 04-28-2007, 07:35 PM   #3
bigtruck81
www.diy4x.com is where its at.
bigtruck81 is offline   Reply With Quote
Old 04-30-2007, 11:32 AM   #4
jimmydean
jimmydean's Avatar
This is my first 67-72 4x4, so bare with the n00b question. But does the 73-87 stuff fit? If so, why not list it as 67-87?
I only see the flip kit for 73-87, that's why I ask.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-30-2007, 12:51 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
If you used a 73-87 style you would also need to change your front hanger to a 73-87 style.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-30-2007, 01:08 PM   #6
jimmydean
jimmydean's Avatar
Is there an advantage to a 73-87 hanger? Would I need different springs?
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-30-2007, 01:17 PM   #7
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
73-87 1/2 & 3/4 have a different offset in the bracket than 72 & older 1/2 & 3/4 due to the 73-87 spring pads are further apart on the axle. 73-87 1 tons have the same pad spread as 72 & older 1/2 & 3/4. So I'm thinking the 73-87 1 ton perches should work on the 72 & older. But I don't know if the bolt holes will line up, or if you would have to drill new ones. Anyone done this?
I'd just like to say 72 73 87 1/2 3/4 one more time
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 05-01-2007, 12:09 AM   #8
bigtruck81
call Kert and talk to him. i'll bet he'll whip up a Flip n Switch for you, if one isnt already in the works, he's a vendor at CK5, and there are plenty of 67-72 guys there.
Old 05-01-2007, 01:51 AM   #9
jimmydean
jimmydean's Avatar
After looking at the ORD install on another site, I will go that route with the upgraded bushings and shackles too. $255 for everything isn't bad and my springs are in good shape.
Thanks for the help. I thought I learned a lot with my 2wd.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-01-2007, 03:51 PM   #10
bigtruck81
i personally have an ORD flip going on my SAS project, and its nice and all, but just not as beefy as the products i've seen (and purchased) from DIY.
the plate style shackles that the DIY kit uses are a big plus too. if they're too long, or too short, get a piece of 3/8" plate, cut to length, drill a couple of holes, and you've got a new set of shackles. no welding, or special tools required.
Old 05-01-2007, 05:21 PM   #11
Stomper_1_Ton
FYI
First gen Shackle flip-n-switch
Stomper_1_Ton is offline   Reply With Quote
Old 05-01-2007, 05:29 PM   #12
1tonblaze
1tonblaze's Avatar
i baught all the up grade stuff from ord and i have to say it is far more beefer then the stock stuff i pulled off . the ord rear shackel flip kit i baught looks far more better then the sky stuff i looked at both kits before i got the ord kit . i got everything to rebuild the whole suspension in my 70 k/5 from them . so far i got all the front stuff on the truck . i am happy with everything i have got from ord and their service
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires
1972 nova plane jane 6 clyinder might sell might keep dont know
2004 chevy s-10 crewcab zr5 sold
1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me
2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went .
1999 k1500 suburban 350 vortec 4l60e leather land yacht .
1tonblaze is offline   Reply With Quote
Old 05-01-2007, 05:31 PM   #13
jimmydean
jimmydean's Avatar
Originally Posted by Stomper_1_Ton View Post
So would it be worth while to get it with the 4.5" shackle too?
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-01-2007, 07:00 PM   #14
cobinder
Everything is work in progress
cobinder's Avatar
I've been to Steves shop (ORD) here in Colorado, they are very together. They use what they sell and they use it hard. In there yard are a dozen hardcore wheelers and a pile of broken parts. They are the real deal and the bushing kits, shackle flip, crossmember, high steer/crossover and other parts I bought have all fit and performed like I had expected them to.
Thumbs up!
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 05-03-2007, 08:43 PM   #15
bigtruck81
you guys sure are eating up the ORD stuff. try and get them to honor the prices on their website when they try to charge you more. there was a big thread on CK5 over some springs that they had tried to overcharge for, and i guess they got pretty crappy with the guy who wanted them to honor their advertised price. whats sad is that ORD is a CK5 supporting vendor.
having dealt with both, Kert's products are built stronger, and with more thought on performance. shipping time was considerably less too, which is surprising for such a small shop.
Old 05-03-2007, 09:41 PM   #16
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I have 3 or 4 ORD items on my truck now. I know there may be better stuff for less but I never had a price issue doing a web entry order or had any issues with their quality. Perhaps ORD is a bit over priced??? Yep….that they are.
When you do as much business with a bunch of rednecks like us as they do, things are bound to get screwed up once and a while and piss someone off in the meantime. There will never be a shortage of people on the internet willing to complain about…well, just about anything especially on CK5.
DirtyLarry is offline   Reply With Quote
Old 05-06-2007, 12:33 PM   #17
Stomper_1_Ton
Sorry it took me so long to get back to your thread.
I would start out with the 4.5" shackle. If that doesn't make your truck sit the way you would like and as long as you don't paint the shackle it can be exchanged for a longer size. If you'd like to give Kert a call and discuss it with him, he's more than happy to talk to guys about their build.
Brett
Old 05-06-2007, 07:26 PM   #18
bigtruck81
agreed, with the high number of guys running 67-87 trucks, being what ORD specializes in, and the high concentration of them on CK5, i could see how that would happen. just never really thought of it that way.
Old 10-13-2009, 11:52 PM   #19
cjthor
OK OK I know...Holy bring back from the dead. I was searching for a rear flip kit and found this thread...but nobody really posted up about the Sky kit. Being in Oregon I contacted my local 4WD shop Rob's Offroad and talked to the guys there about flip kits. They do alot of Yota stuff so they do alot of business with Sky. I ordered them today and I will take some pics of install for you all to see! Here's a link to my cardomain page
JP
70 K20
74 CJ5
cjthor is offline   Reply With Quote
Old 10-15-2009, 06:59 AM   #20
Let us know how you like those Jackers.
Old 10-15-2009, 12:15 PM   #21
Dave Reed
Dave Reed's Avatar
Subscribed!
Dave Reed is offline   Reply With Quote
Old 10-16-2009, 05:57 PM   #22
DieselEater
DieselEater's Avatar
Just remember that you're gonna have to buy or make an offset spring perch to pull the rear axle back to center of wheel well!!!!!
I opted to make my own, but you can buy some from whoever you get your shackles from.
After looking at my ORD shackles, I thought to myself "Jeeez, I coulda just made some of these."
They are great!!! Just not that big of a deal to make yourself....
JMO...
A..........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
