04-27-2007, 02:02 PM | #1 |
Smonty
Can U use a 73-91 suburban gas tank on an 87 Blazer?
Can U use a 73-91 suburban gas tank on an 87 Blazer? If so, is there any modifications necessary to the Blazer Frame. Need to increase the fuel capacity in my blazer. Any suggestions would be appreciated. Thanks! Ernie
72 2WD Blazer 68 SWB Fleetside 67 SWB Stepside 2005 Chevy 1500HD Crewcab 56 Chris Craft Mahogany Runabout Looking for 36 Chevy 1/2 Ton P/U Project |
04-27-2007, 02:29 PM | #2 |
Slots go on anything!
Re: Can U use a 73-91 suburban gas tank on an 87 Blazer?
87-91 Sub tank will work (has correct baffles for fuel injection). Use corresponding sender and fuel tank straps also, and it should bolt right in.
04-27-2007, 08:02 PM | #3 |
Smonty
Thanks for the info!
04-27-2007, 10:49 PM | #4 |
a 25 gallon tank should measure 29"x28"x11"
a 31 gallon tank should measure 29"x28"x13" the suburbans ran the same tanks but they also could have a 40 gallon tank the 40 gallon tank measures35"x29"x13 if you get the 73-86 tank you will need to keep it above the 1/4 tank level because they have no baffles in them. I have never tried the 40 gallon tank in a blazer and i do not think there is enough room for it. |
04-28-2007, 06:37 AM | #5 |
Smonty
The 31 gallon tank sounds like my best bet. Thanks! Ernie
