Old 04-27-2007, 09:10 PM   #1
fishmunger
fishmunger's Avatar
Lowest static drop for towing?
Hey guys, I have my 64 short fleet lowered 4 up front and 5 out back right now. I'm using it tow my boat ~350 lbs tongue weight. I've c-notched it and relocated the shocks, it works really good. I was wondering if anyone thinks 7" rear drop will still work? I don't want bags, it's my DD and I don't have the money anyway, I don't want to run bags with schrader valves either. So would 5" springs and 2" blocks be ok, or would I be better off to stick with what I got now (3" springs, 2" blocks)?
thanks,
Nate
fishmunger is offline   Reply With Quote
Old 04-28-2007, 12:10 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Lowest static drop for towing?
Why not use helper bags and have the best of both worlds?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-28-2007, 03:48 PM   #3
fishmunger
fishmunger's Avatar
i really dont want any bags on my truck. i want to either drop it some more with springs, or leave it as it is. i was just wondering if anyone here has towed with a 7" drop...
Nate
Old 04-28-2007, 05:33 PM   #4
SCOTI
SCOTI's Avatar
I don't think I've seen anyone on here that is that low w/a static drop & still tows a trailer. My truck is that low, but I switched to bags just to be able to level the truck back out once a loaded trailer was hooked to the tail end.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-28-2007, 10:18 PM   #5
smbrouss70
smbrouss70's Avatar
I have a 8" drop on the rear (6" coils and 2" blocks.) I haven't towed anything real heavy, but with a small utility trailer holding a bare cab I was bottoming out on my bolt-in c-notch quite a bit. It was enough to cause me to decide that the next time I tow ANYTHING with it, I will have bags in the rear.
Hope that helps with your decision.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-29-2007, 07:47 AM   #6
see ten
WTB this ad
see ten's Avatar
If you're looking at changing springs why not split the difference and go with a 6" drop coil and ditch the blocks? I would think with the bolt in notch you wouldn't ever have a problem but I have no experience with towing in these trucks after a drop. You could call ECE and talk to a tech, they might be of some help.
see ten is offline   Reply With Quote
Old 04-29-2007, 09:54 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by see ten View Post
If you're looking at changing springs why not split the difference and go with a 6" drop coil and ditch the blocks? .....
That would create more trouble if he wants to tow. Those 6" springs would never work under a load.
The reality of it is your going to have a hard time towing with that much drop unless you reconsider your position on options.
Articles-
"Refining Sierra"
Old 04-29-2007, 11:17 AM   #8
SCOTI
SCOTI's Avatar
thanks,
Nate
Swapping to manual fill bags will get you where you want so why not bags? You're going to go through the effort of swapping springs anyway.... installing a couple of bags isn't much more work.
From SuicideDoors site:
255c 2500# Firestone air bags @ $70ea x 2 = 140
25ft 1/4" Reinforced DOT air line @ $6
90° elbow fittings @ $5ea x 2 = 10
Schrader fittings @ $5ea x 2 = 10
Grand total for everything = $166
Price for 5" drop springs from board vendor GMC Pauls = $115
$51 difference to get that 7" drop & still tow a load.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-29-2007, 12:16 PM   #9
cdowns
cdowns's Avatar
try the 5" springs with the blocks /just dont get rid of what you have now till you find out how you like it. once you're sure that you have the setup you like sell the other pair of springs// springs are cheap so either way you'd not be out a heck of alot of money
