Wrong freaklin starter Solenoid!
My 71 wiring on the Solenoid has R & S. Yellow & Purple wires in the harness. However the Solenoid installed on my starter only has one terminal. Will I have to get the older Solenoid with the two terminals or can I hook both of the wires on the one terminal???? Anyone know? Sure hate to remove that starter again. Whats my options?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Designated A-hole!
Re: Wrong freaklin starter Solenoid!
You're best bet is to convert to HEI, then you won't need the other terminal. The points dizzy that came stock uses ~9v (supply wire is a resistor wire)while running, for starting purposes the yellow wire supplies 12v to the coil for a hotter spark. HEI uses 12v all the time so you don't need the extra terminal. Basically the news is that you need the 2 terminal solenoid if you have the points dizzy.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
I have the HEI installed except the wiring which is what I was doing wiring the starter POS lead. So I can forget the yellow wire & run a unfused to the HEI?
Designated A-hole!
Yeah, if you have HEI you can eliminate the yellow wire altogether. I ran a 12ga. wire from the ign unfused terminal in my fusebox to the distributor and that's it, although most folks will recommend putting an inline fuse in it somewhere.
Designated A-hole!
Click on the Index link in my sig for the FAQ writeups on the HEI wiring.
Thanks..yeah I went & found Longhorn Man's FAQ & re-read it. 12 ga with a fuse..Thanks again!
Designated A-hole!
No problem.
