Old 04-27-2007, 10:27 PM   #1
harleyx2
motor plates on 73-87 crossmember swap
so tomorrow im doing the 73-87 crossmember swap into my 68. which motor mount plates are the easiest to install and not have to move the motor mounting position foward or backwards, i hear that the newer 73-87 style motor mounting plates move the engine backwards. is this true? i have a v8 with auto trans. and i dont want to have to move or modify the trans mounts or crossmember. would it just be easier to install all the newer stuff onto my existing crossmember? thanks.
harleyx2 is offline   Reply With Quote
Old 04-27-2007, 10:35 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: motor plates on 73-87 crossmember swap
You should be able to use the same mounts and the mounts should bolt into the same place as before....
LockDoc
Leon
Old 04-27-2007, 10:50 PM   #3
harleyx2
you mean the new mounts or the old mounts. it looks like if i use the old mounts i will have to drill holes in the 73-87 crossmember for the bottoms to bolt up. if i use the newer style mounts it looks like ill have to drill holes in the 68 frame for the top of the engine mount plates to bolt up.
Old 04-27-2007, 11:21 PM   #4
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Ok, I'm confused. I understand swapping the a-arms, spindles, etc. (I have '76 model A-arms & 73-87 dropped spindles on my '68), but why change the crossmember? I guess I don't understand what you're trying to accomplish. I'm not trying to be a jerk, I just don't get it.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 04-28-2007, 08:28 AM   #5
harleyx2
if you change the crossmember you dont have to unbolt all the control arms and stuff. just roll the new crossmember in. i have a whole 80 model truck to get the brake lines off of so i thought it might be easier this way. from what i red alot of people have done it this way. im just trying to find out the easiest way.
Old 04-28-2007, 09:11 AM   #6
LockDoc
LockDoc's Avatar
I meant the old mounts. I don't remember having to drill any holes but CRS runs rampant in my shop..... At least using the old mounts (even if you have to drill a hole in the crossmember on each side) you would be assured that the engine will be in the same place and you won't have to worry about moving the rear crossmember, and driveshaft mods. If everything lines up on the new ones except for the two holes in the frame I guess it would be which ever would be the easiest to drill new holes in. I've never messed with the newer mounts.
Just my 2¢ worth...
LockDoc
Leon
Old 04-28-2007, 09:44 AM   #7
70GMCer
70GMCer's Avatar
I plan on trying to use the newer motor mounts on the 84 burb member swap and hope the the engine/trans will be in the same place. It's a lot easier to run the mount bolt thru the side, than those PIA bolts that mount up thru the bottom..
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-29-2008, 05:00 PM   #8
mtm_seven
Loading.....
mtm_seven's Avatar
It's my understanding that the 73-87 xmember will allow you to pull the oil pan without lifting the engine as well as use the newer style motor mounts.
I guess I have the same question though - if I want my motor in the forward position in order to make it easier for distributor work and such, what mounts are recommended?
-M7
'69 SWB GMC 5.7 EFI
‘69 C/10 SWB patina survivor
‘71 K20 LWB GMC
'72 K5 1-ton gear 468BB
‘79 K20 LWB GMC
‘86 K30 GMC High Sierra C&C Single Cab
‘94 LWB GMC 2500 4x4
'96 SWB Single Cab 5.7
‘99 SWB Z71 Single Cab
'01 K2500 Yukon Safari 6.0
‘06 1500 LWB 4x4 5.3
‘06 2500HD Single Cab C&C Duramax 4x4
'08 2500HD x-cab duramax 4x4
'11 2500HD Single Cab Duramax 4x4
mtm_seven is offline   Reply With Quote
