Old 04-28-2007, 08:29 AM   #1
.030over
Junior Member
.030over's Avatar
Air bag selection - Type and ratings?
I have been trying to soak up all of this air suspension info as I will be doing both ends on my ‘67 swb big block truck. I am new to air bags other than an air assist system on my ‘94 and I have found just about everything that I have wanted to know on here except bag selection. Now, I know this is probably a personal choice thing but I’m wondering more about type or rating and less about brand. 2500, 2600, 150psi, 400psi etc. I want to have a nice ride and don’t care so much about speed or extremes. My truck will have a slightly narrowed trailing arm 9" rear with bags mounted just ahead of the axle and a c notch only. Front is a 73 up setup with 3" spindles. Also, Is the need to do 8 valves because of air transfer on turns? Is that still a problem if I use 1/4" lines? I was planning on keeping this as simple as possible but I can see how that might be a problem. Sorry for all of the “newbie” questions. Get me straight!
Scott
'67 SWB big block project
'85 C60 school bus motorhome conversion
.030over is offline   Reply With Quote
Old 04-28-2007, 10:59 AM   #2
randomhero472
randomhero472's Avatar
Re: Air bag selection - Type and ratings?
I think the majority of us on the board are running slam specialties RE7 bags, both front rear.. im using a bolt-in c-notch and stock arms up front, very easy and cheap.. check out www.***************** they'll have brackets for the front ($60) and everything you'll need.. most guys have just bolted the bag in place of the coil in rear, pretty much a direct swap w/a couple of extra holes being drilling.. hope this helps
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 04-28-2007, 11:45 AM   #3
jimmydean
jimmydean's Avatar
Yes, 8 valves for ride/performance/safety/handling/adjustability/etc/etc/etc
I ran RE7 front and RE6 rear. That's how the kit I bought came, but I would have liked RE7's for the back. With RE6's I had a little over 1000 pounds of hay in the bed and was still level with only about 100psi.
Don't skimp or you will end up spending more later to redo it.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-28-2007, 11:49 AM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Firestone 255c, 2500 lb bag
* 2500 lb. 3/8" single port air bag
* Min. Height: 3"
* Installed Height: 4.5"-5"
* Max Height: 7"
 Diameter(Inflated): 6.5"
Firestone 224c, 2600 lb bag
* 2600 lb. 3/8" single port air bag
* Min. Height: 3"
* Installed Height: 5"-5.5"
* Max Height: 8"
 Diameter(Inflated): 8"
RE-6
Diameter: 6"
Min height: 3"
Max height: 10"
Max PSI: 180
RE-7
Diameter: 7"
Min height: 3"
Max height: 11"
Max PSI: 180
RE-8
Diameter: 7.75"
Min height: 3"
Max height: 11"
Max PSI: 180
RE-6 Replaces a firestone 255c or contitech 2500# bag. (Front)
RE-7 Replaces a firestone 224c or contitech 2600# bag. (Rear)
RE-8 Replaces a firestone 2800# bag. (Rear duallys)
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 04-28-2007, 01:56 PM   #5
Shane
Shane's Avatar
i have Firestone 2600 lb. bags in the front ... Firestone 2,500 lb bags in rear under a 67 with a small block.
Shane is offline   Reply With Quote
Old 04-29-2007, 09:24 AM   #6
XXL
Señor Member
XXL's Avatar
... 'cept mine is a 6-banger.
XXL is offline   Reply With Quote
Old 04-29-2007, 02:06 PM   #7
mxer
mxer's Avatar
How many inches lower will the truck sit at its lowest safe ride height with just the bags.I'm looking to do the bolt on bags with a notch and drop spindals.Anybody got any pics of there trucks with this combo.
mxer is offline   Reply With Quote
