Old 04-28-2007, 08:56 PM   #1
creeldaddy
creeldaddy's Avatar
pitman arm
how do you take off the pitman arm does it just pop straight off with alittle persuasion or do you need a special tool?
creeldaddy is offline   Reply With Quote
Old 04-28-2007, 09:07 PM   #2
kwmech
Re: pitman arm
You will need a puller, the splines are tapered, so when the nut is torqued down it locks it very tight.
Old 04-28-2007, 09:15 PM   #3
Big Block
Big Block
Big Block's Avatar
Re: pitman arm
You can pick a pitman arm puller up at any auto parts store. They are not to expensive.
Big Block is offline   Reply With Quote
Old 04-30-2007, 10:58 AM   #4
Orange
Licensed to Thrill!
Orange's Avatar
Re: pitman arm
I used a puller alright...looked like this...
I would recommend it their way though.
It's not the easiest way.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 04-30-2007, 02:06 PM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: pitman arm
You need this
sneakysnake is offline   Reply With Quote
Old 04-30-2007, 02:26 PM   #6
st1x10
st1x10's Avatar
Re: pitman arm
Originally Posted by sneakysnake View Post
You need this
That is the way to go. I have one at home, I just need to get the part and replace it.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
