Old 09-09-2002, 09:47 PM   #1
72cheyenne402
Lift Springs
Where can I get 2" lift springs for a 2wd half ton?
72cheyenne402 is offline   Reply With Quote
Old 09-09-2002, 11:56 PM   #2
slam33
slam33's Avatar
fronts or rear, you didn't say. If it's the fronts you can use BB sprigs if you have a SBC. 2 inches is the max you can go becuse of ball joint angle limit. It's going to be very stiff up front. For the back, your guess is as good as mine. I run a spacer on the frame side
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-10-2002, 08:49 AM   #3
Mike C
Mike C's Avatar
Fabtech, Rancho and JC Whitney should all be able to help you out.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-10-2002, 09:07 AM   #4
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
If you've got coil springs front and back like me, then you can get 2" lift springs from Eaton Springs. I ordered mine last week and they should be coming by the end of this week. Mickey's a really nice guy and can answer any questions you need. His site is www.eatonsprings.com .
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
