Old 04-29-2007, 04:10 AM   #1
hewlett2002000
hewlett2002000's Avatar
homemade wiring harness(again)
ok yall im making my wiring diagram for my homemade wiring harness. ive got all the ignition and accessories on paper. but i need help with the charging. im using a internal regulater alternator(not 1 wire). obviously Batt goes to the battery. but 1 and 2???? i think 2 goes to the battery as well. but what does 1 go to? please help.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 04-29-2007, 12:08 PM   #2
19GMC63
19GMC63's Avatar
Re: homemade wiring harness(again)
One wire goes to the dash idiot light
19GMC63 is offline   Reply With Quote
Old 04-29-2007, 12:23 PM   #3
hewlett2002000
wwhat if i have guages? then where does the wire go?
Respect:
Old 05-01-2007, 03:24 PM   #4
Ham-er
I think 2 goes to the battery as well.
hey hew, one of the terminals in the flat connector does go to the battery as well but NOT directly! It powers the alternator field is what it does from the battery. It is usually connected thru the ignition switch so that ur alternator field coil doesnt drain your battery when the truck is turned off. A simple way to go with this is turn your internal regulator alternator into a 1 wire alternator by replacing the regulator with an S (Self Exited) part. Marked SI after the part number If i remember correctly.
Ham-er is offline   Reply With Quote
