Old 04-29-2007, 10:21 AM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Big block bracket question?
Are the power steering and alternator brackets the same from a tall deck big block to a regular big block? Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-29-2007, 11:51 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Big block bracket question?
The alternator brkt mounts to the head (stock location) so in a tall eck its .4" higher up. (my AFR heads are tapped for accesories for what thats worth). Power steering is in the same place on the block (lower driver side).
Tom
Tom Vogel is offline   Reply With Quote
Old 04-29-2007, 10:42 PM   #3
too much stuff
Roadtrip!
Thanks tom. So are you saying the alt. bracket will work fine but need a little bit longer belt? Also, the power steering pumps are the same? They look the same, just want to make sure. Thanks, Eric
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 04-30-2007, 06:21 AM   #4
dwaite72lnghrn
If they are stock brackets like my '72 the alt, uses the power steering bracket and the head to mount so you would have a problem. Not sure on other years or aftermarket.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
