Old 04-29-2007, 03:12 PM   #1
gouldie
clutch replacement
the clutch in my truck is gone, 67 250 3 on the tree, and was just wondering how hard it is to replace the clutch and anything i need to watch out for.
i tried the search and came up with nothing.
thanks,
chris
67 c10 250 I6 3 on the tree no options
air ride, paint and big block coming within the next 23 years
2001 mustang gt for going fast
gouldie is offline   Reply With Quote
Old 04-29-2007, 03:39 PM   #2
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: clutch replacement
Its not hard at all. Very briefly you must take the driveshaft out, transmission out, dustcover off, pressureplate & clutchdisk out, get flywheel ground & reassemble in reverse order. The hardest part is reassebmly because you have to line up the clutchdisk properly & tighten down the pressurepalte. Then you have to slide the trans in place while aligning the splines in the clutchdisk. Its all heavy & space is limited in there for reassembly. I bought 2 6" long bolts the same thread as the top two bolts holding the trans to the bellhousing & ground the heads off. You then thread them in by finger & then they become alignment guides for the trans to slide into place on. Very handy. A shop manual is the best reference here. It will walk you through it. I'm all about the 11" & 12" clutches but it is a personal choice. If you have any questions, dont hesitae to ask. I have attached a link on the subject below:
here is an oldie but a goodie:
http://67-72chevytrucks.com/vboard/s...d.php?t=179528
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 04-29-2007, 03:52 PM   #3
gouldie
thanks for the fast reply. so pretty much drop the tranny unbolt and replace. how long does it usually take?
Old 04-29-2007, 04:05 PM   #4
passthebuck
It could be done in an afternoon if you have everything there & ready, but I took my flywheel to be ground & I also took the pressureplate, clutch disk & throwout bearing to my local clutch shop so that I got the correct parts. I changed the rearmain seal too while I was there & that took more time. Cleanliness is important on reassembly - lots of brakecleaner on the pressureplate & flywheel & try to avoid fingerprints on the clutchdisk itself. put the tranny into neutral before pulling it apart (important), & if they are bad, get new bushings for where the rods attach to the levers on the trans-this made a huge improvement in shifting quality. I think Mr. Gasket has good aluminum ones. & put a new boot on the clutchlever where it goes through the bellhousing-they are always rotten! A haynes manual is a good idea.
some more links i have saved:
http://67-72chevytrucks.com/vboard/s...d.php?t=152767
http://67-72chevytrucks.com/vboard/s...d.php?t=148595
passthebuck
#5642
Old 04-29-2007, 05:42 PM   #5
sodak69c10
sodak69c10's Avatar
lots of good advies
and if you have a friend or access to a hoist it make thing alot easier
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
