man this is ugly
i dont like how far this booster/master sticks out there... is there any way to relocate it back against the firewall, so it'll clear an auto columb shift arm?
or should i just go with a 7in booster (so it can clear the auto shift arm), or no booster...BTW im running discs all round, so i think i'd like somewhat of a effertless brake pedal feel... here are a few pics of what im talking about, thanks mike nutt for the last pic (for a refrence of a non-booster set up) ![]() ![]() ![]() ![]() |
Re: man this is ugly
You could run the setup that goes underneath of the dash and have no booster on the wall at all.
you can relocate the booster and master under the floor so theres nothing there
$0.02 worth
hydro boost then you don't have to have good vacuum (i.e. big cams ) only thing is you got to have right ps pump and two hoses running to booster
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
if you are good at fabrication you could cut down the mounting bracket or another one to mount to the firewall.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
Oilfield Trash
93 chev booster and master, little fab work to do it though, iirc, all that has to be done is drill 2 new holes for the bolts, enlarge the firewall hole a little, and the rod a couple of inches. I just cut the 93 rod end off, and welded a portion of a 67-72 style on, that way the length can still be adjusted with the threaded section on the old rod end.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
![]() Join Date: Oct 2005
You may not be happy with that booster, but that engine looks fricken great.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
no offense but IMO those plastic covers on the engine look alot worse than the brake booster, but then im old fanshioned
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
It's hard to make a GenIII motor look "old fashioned". Without the covers, those motors (in stock form) look very cluttered. Covers clean it up.
69fatmotor
68 short step , WILWOOD sell a small bore (1")tha works well with out power assit ,the master cylinder on my truck has an 1 1/2" bore which works well it just reqires a little more effort. i will be changing to this set up when i add the rear disc
Remove it all and stop Fred`n`Barney style
blood type; Retumbo
I like Blue85s idea. just use a large bore MC. preferably a 1 1/4 or 1 1/2" bore. 4 wheel discs take more volume.
so those are the gen III Caddy covers I hear so much about. it looks like a plastic armadillo of sorts. |
#13 |
mount it under the dash, i did on my stang.
#14 |
![]() Join Date: Aug 2005
Not to change the subject but I haven't seen a Gen III Caddy Engine before. Where does the air intake finally wind up?
#15 |
![]() Join Date: Feb 2004
well your gona have to do a web search but i know for a fact that a company is selling an booster that works off electric motor and small hydraulic pump, i seen it in a hot rod book and its intended for bad a$$ motors that wont support the vacume requirements of a booster. it is also small and could probably be moved around to your needs. hate to know the price but check it out it might not be that bad....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#16 | |
Weekend Warrior
![]() Paint the Booster & Master the same color as the firewall, Inner Fenders, Rad Support and it will blend in. The reason that you notice it so much now is because of the gold color - think of it as a gold tooth ![]()
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#17 | |
Licensed to Thrill!
It costs a little bit. DLB |
#18 |
Active Member
I did the same as "Blu85" and used one from a '96 Tahoe. Little fab work and it mounts tight to the firewall. It's still a big booster but it deletes that stock bracket & linkage mess that really detracts from a shaved firewall.
#19 |
ive seen remote brakeboosters , when you use one of those you only have a cylinder like a hydraulic clutchcylinder hanging on youre fire whall and you could mount that booster thing just about anywhere as long as you can get the vacuumhose to go there too (or mount a vacuumpump next to it )behind the cab under the bedfloor for instance http://ecihotrodbrakes.com/remote_booster.html there you go
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#20 | |
ttt this is a good answer..think I will do the 93 conversion
#21 |
really like that caddy! wicked! bet its torqey as all hell!
![]() Last edited by albertarose; 04-30-2007 at 08:47 PM. |
#22 |
i wanna keep the master under the hood..so i like the wilwood idea, and also the 88-99 master booster combo, but the problem i see with that is the master isnt designed for a disc/ disc set up (big bore).... so i bet i can use my master/prop valve with that booster.?
#23 |
Oilfield Trash
Why not look into a 99+ booster/master combo from a 4wheel disc truck, shouldn't be too much harder to mount than the 88-98 booster
