Sierra Grande Club
I "thought" I knew what I was doing.
I took off my cowl to remove the leaves down near the vent. No worke. What do I do now??
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: I [I]thought[/I] I knew what I was doing.
after you get the leaves cleaned out ( i had a shop vac and went through the kick panel vents with a fletible hose)i used some old metal window screen and cut it fit under cowl and blocks vent and keeps the leaves and stick out
i dont ha ve a camera with me in town but ill see if i can find a picture of the screen in place
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
Next project: 1970 K10
Take the vent doors off.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#4 | |
Sierra Grande Club
st
Sierra Grande Club
I'll give this a shot next, is it hard????
Naw, it's not hard. Take the screws out that hold the handle on to the kickpanel, then lift the door up, pull the bottom out, then pull the door down, and it's out.
Re: I "thought" I knew what I was doing.
ok got camera now i going to take a pic of screen as soon as my battery charges as for how i attached it i cut hole in screen that line up with the wiper posts and wishield washers then i laid then screen out so that the phillips screws that go into the cab also hold the screen in place as soon as i get the pics loaded i'll just edit this message and insert pics
