Old 04-29-2007, 06:15 PM   #1
six4flat
six4flat's Avatar
stock wheels
i seem to cant find a set of stock 6 lug wheels anywhere
six4flat is offline   Reply With Quote
Old 04-29-2007, 07:16 PM   #2
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Re: stock wheels
You can find the stock 6 lug rims on Gm trucks up through 1970. Anything from 1971+, look for the truck ralley's off of the 4x4 trucks.
I'm running set of 4 1967 GMC stock truck rims on my '62 C10. Pick-N-Pull usually has these truck rims up in Stockton, Ca right off of hwy99.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 04-29-2007, 08:39 PM   #3
six4flat
six4flat's Avatar
Re: stock wheels
i found some like these at the pick n pull near me theyre 15 x 10 well they rub in the front?
Old 06-03-2007, 04:45 AM   #4
LILRED66
LILRED66's Avatar
Re: stock wheels
The front and rear wheel house is plenty bid to run most 15" wheel & tire combinations without rubbing. The key is the bolt pattern and the back spacing. I have a set similar to the ones in the picture and they work great and look pretty good, as well.
LILRED66 is offline   Reply With Quote
