Heres a question for you guys running ram horn exhaust manifolds on your trucks. How easy is it to get to your plugs when its time to change them and can you drop your starter without pulling the exhaust manifolds? I have a 72 4x4 with headers and its a 5 hour ordeal to get at the starter. Plugs are a nightmare and I seem to always be doing some thing around them. If the ramshorn manifolds are easier then I might switch over to them when I get my exhaust system done. I already have one manifold off my 327 solid lifter engine in my 64 Vette so I would only need to buy one.
Re: Ram Horns, Sparkplugs and Starters
The only problem I had with the plugs were the two nearest the brake booster. It's a pain to find a good spot to make them snug. I thought I had them snug until a friend noticed one was pulsating.
Not too much experience trying to get at the starters. Although I did try one day and gave up rather quickly. I'm not sure the rams horns were the cause, though. Hope this helps.
1970 C10 ![]() |
The rams horns are a good choice; if you've already got 1 rams horn, (is it a 2 1/2 " outlet?) then you only need to find 1 more obviously. They are a pretty free flowing manifold as I understand, and will last almost indefinitely, (unlike steel headers -i.e rust) and I believe changing plugs, or a starter would be much simpler with factory rams horns- should not be a 5 hour ordeal.Best of luck, Lew
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
I just put plugs in mine (ramshorns) took all of 15 min. Starter takes a little longer 20 min (but I have a newer perm magnet delco starter also).
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Dave's not here, man
I have factory ramhorns but I'm running them on a 305 from an '86. I couldn't get the starter off w/out removing the y-pipe. (I did away with that eventually) I haven't ever had problems with plug removal, though.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
I have factory ram horns AND factory smog piping going into them. Changing pluges is a PITA but not that tough.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
Sierra Grande Club
Are you guys using the factory heat shield to protect the plug wires?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Thanks for the information fellas. I think I'm gonna be going to the ram horns later on. The one I have is 2 1/2" outlet.
#9 | |
![]() Join Date: Nov 2004
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
not to hijack this thread, ( just saves more room for others posting new topics )
Plugs are easy to change.. it's my RAMHORN that's needs changing... looks like MT. ST. Helens, ready to blow...
1941 Chevy 1/2 ton Street Rod: 327 cu,/350 auto, 'Stinger ' - JULY 2007 CUSTOM CLASSIC TRUCK magazine. 1967 Chevy 3/4 ton standard bed, 350 cu./400 auto, w/ 83 - 3:43 rear end...sips gas.... |
I just changed the starter in my 48 p/u with Nova front clip and Ram Horns, took about 15 minutes As for the heat shield, I use a Ford starter solenoid in addition to the heat shield. I mounted mine by the battery with an emergency jump switch mounted low on the inner fender well. You might want to mount the solenoid higher if you have a history of battery problems so you can hook jumpers to the teminals. Chevy starter solenoids have a history of not wanting to engage when they get hot, the Ford solenoid can be mounted outside the heat source and almost never fails.
hooberjon@yahoo.com "Life's Been Good To Me So Far" 1941 Chevy PU (new project, right out of the field) 1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor 1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console. 1996 Geo Tracker 2x4 1996 Geo Tracker 4x4 |
I will put a heat blanket on my starter when I put my new engine in, the ramhorn is only about an inch away, besides that, no problems changing plugs. I'd take em over headers any day.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#13 |
Next project: 1970 K10
Plugs are simple to get to. One of the things that can/will determine how easy the starter is to get to is how the exhaust was ran. I can just unbolt and drop my starter, but I have seen some downpipes that are bend at the bottom in a way that makes the starter difficult to remove. I used heat shield wraps on both downtubes on mine, one for looks and two because the right side pipe is real close to the starter. Go with the ram horns!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#14 |
go with the rams, plugs are easy to get to, starter is also easy, depending on how you route your exhaust
#15 |
Who's got steelies?
![]() Join Date: Feb 2006
Ramhorns are the best, plugs are easy to get at, no starter problems, much quieter under the hood. I had the displeasure of changing the plugs on a friend's '70 c/10 sbc with headers: talk about a pain. I'm not doing that ever again. Go ramhorns.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#16 |
They are really expensive, but the stainless ram horns that speedway motors makes are just so neat looking.
